Question about HP ProBook 6470b Intel Core i5-3320M 2.60GNotebook PC - 4GB RAM, 500GB
Bios eprom password reset
Is any way to recover bios administrator password or to reset the bios or eprom. i have tried with cmos battary but doesent function
Kindofcheap
  • 241 Answers
SOURCE: bios password forgotten
Are you tryingto access the bios or is this asking you when you reboot at the start up screen?
Posted on Aug 28, 2008
acdr
  • 1913 Answers
SOURCE: reset bios password
u can reset your bios 2 ways.
(1) pull away your cmos cell for 15 minutes from laptop mother bord.
(2) u can find jumper nearly cmos cell or in corner of circuit bord.set it in 1-2 position thenpower up the lsatop then again set in 2-3 it isd its original position.
Posted on Jan 03, 2009
brannfenix
  • 81 Answers
SOURCE: hp compaq nx8220 - Administrator password cannot be reset
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
Posted on Jul 28, 2009
  • 21 Answers
SOURCE: EliteBook 8530p bios password
You may need to contact the manufacturer to reset the BIOS password. If you can find the service manual of the computer, it may have instructions for resetting the password. It may involve taking the computer apart and shorting a couple of pins together. Service centers may have a special part, which when connected to the computer, will cause the password to be reset.
Posted on Oct 09, 2009
  • 74 Answers
SOURCE: compaq 8150p bios password need to be reset. Is
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 30, 2009
How to reset hp elitebook 8460p bios password?
Generally, there are two ways to reset forgotten HP BIOS password. One is forcing BIOS/CMOS to reset itself to its stored defaults by removing all power to it. The other is to use a program to either locate or identify the password and reveal it to you or erasing the password entirely.
And the most easiest and convenient method for erasing dynamic BIOS/CMOS settings is to remove battery directly from the motherboard. It applies to most motherboards besides HP Elitebook BIOS. At this moment, HP Elitebook based on UEFI Bios provides a tool to reset BIOS password specially - HP SpareKey.
How to reset BIOS password with SpareKey?
1. Before forgot BIOS password, you have set answers to three predetermined personal identification questions.
Write down the answers to these questions and put them in a safe place, away from the computer, so that you can always access them.
2. When you cannot remember the password to access the BIOS on your computer, turn on the computer and immediately press the ESC key to display the Startup Menu. And then press the F7 key.
3. HP SpareKey wizard pops up and prompts you for the answers to the three personal identification questions. If you successfully answer the questions, you are granted access and you can reset the password.
If you do not answer the questions correctly in the three attempts, you will be locked out of your computer. And then you must contact HP for assistance.
Note: HP SpareKey cannot help you recover a Windows 7 or Vista administrator account password. It is intended solely to recover system-level passwords.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Aug 23, 2013 | HP Computers & Internet
Please help me recovering password for WD 500GB HDD
recover your hdd using recovery software (e.g. Hiren's boot CD)
Aug 16, 2011 | Computers & Internet
How can i reset the bios power-on password for hp 6720s ?
Do you want to know about bios power-on password reset on HP 6720s?
Turn to Reset HP BIOS/Administrator Password
It shows you how to reset HP BIOS password with SpareKey, and how to reset HP administrator password with effective Windows Password Genius in just 2 minutes.
Get a video learn how to use it:
http://www.youtube.com/watch?v=-vrVcFaUATg&feature=youtu.be
Mar 05, 2011 | HP Compaq 6720s PC Notebook
How to unlock computer? forgot password
If you locked your computer using the BIOS lock features st start up, and you have a button battery on your motherboard, remove the battery for a few minutes while computer is off and re-install it. That will clear the CMOS settings and security passwords. If your computer is a newer model, ie. NO button battery, it utilizes a EPROM chip that you cannot re-program yourself. It has to be done by Dell, or a Dell Support Tech who has the tools to flash the EPROM chip. If you are locked out of your OS, ie. Windows, You can use a special CD disc that has password recovery and reset features to find/change the Windows password. You must change the Boot order in the computer to CD as first boot device when using the disc.
Jul 18, 2010 | Dell Computers & Internet
Reset emachine bios password
this is very simple to reset emachine bios password
simple open cabinet of cpu then remove litheum battery of emachie. restart the machiche with battery the password will reset.
Enjoy..
May 06, 2010 | Computers & Internet
Power-On Password reset and SVP
The supervisor (SVP) password is stored in a chip called 24RF08.It can not be reset by disconnecting the BIOS battery or shorting any jumper.
Nov 24, 2009 | IBM ThinkPad T43 Notebook
I want to no how to reset a dell d610 because i forgot my password l
You need to temporarily remove the CMOS battery from the motherboard to reset the BIOS password.
Nov 23, 2009 | Dell Latitude D610 Notebook
Oct 09, 2009 | HP EliteBook 8530p Notebook
BIOS PASSWORD REMOVAL on a toshiba satellite L45 S7409
This link describes the bios password reset for various Toshiba models (it's at the top of the results list), hopefully this will help you take care of your problem.
I would also think that Toshiba support would be able to assist you with this should you call them.
Apr 28, 2009 | Computers & Internet
HP ProBook 6470b Intel Core i5-3320M 2.60GNotebook PC - 4GB RAM, 500GB Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
