How is the functioning of washing-machine model GL 5 T
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Hi, I'm looking for a
Hi.
Unfortunately Gala does not make any documentation available for online download.
The GL95LA should be the 5Kg 800 Rpm model.
To get the manual click and open Gala page here, then scroll down Gala page and fill the form titled"Contact us about 5Kg Gala Washing Machine 800rpm" .
In the form write model number and part number of the washer, as printed on servvice tab and ask to send you a manual for your appliance, possibly in PDF format.
Regards.
Ginko.
Posted on Aug 30, 2010
Hi ,
How to operate washing machine of GL 95 LAQ -1 ?
Thanks
Posted on Jul 26, 2013
How to reset a Kenmore model 2661532210 washing machine
try this.if it does not work then go to this link and see if it helps you out...... Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website............
Reset Buttons for Washing Machines
Dec 08, 2016 | Kenmore Washing Machines
Hi All, I have Simpson Toploader SWT704 7.5kg washer. Its a 5 years old machine and recently it started thumping noise like an earthquake at the end of the washing cycle.
Try utube there is some videos there of similar machine designs that are very helpful or you can download a repair manual for your model through Simpson/Electrolux....hope this helps gl
Mar 15, 2016 | Simpson Washing Machines
Wbvh5100hww
Hi
how to operate GALA washing machine of model no. GL 95 LAQ-1
Thanks
Jul 26, 2013 | Washing Machines
Washing machine SF-110LJ sign Fd on display
My washing machine Model SF-110LJ does not working and show Fd on
display. Please assist.
Nov 30, 2012 | LG Hitachi Washing Machine Lint Filter...
The washer shuts down in mid cycle
Hello. LG washing machines come in a widevariety of models, each with unique features, functions and design. Many of thebasic functions of each model are universal when it comes to running the washcycle. If the washing machine stops in the middle of a wash cycle, the firststep that should be taken is to perform troubleshooting steps to determine thecause of the problem. After the source of the trouble has been established, itcan be resolved in most cases by continuing the troubleshooting process. 1 Make sure the lid is completely closed. Certain partsof a wash cycle will not start if the lid is not closed.
2 Check the load to see whether it isunbalanced. If the washer gets off balance, it may stop in the middle of acycle. Redistribute the clothing so that it is evenly balanced around the drum.
3 Make sure the hot and cold water faucetsconnected to the washing machine are turned on fully. If the washing machine isnot getting enough water, it will not be able to complete the cycle.
4 Inspect the drain hose for clogs orobstructions. The washing machine may stop if it is unable to drain waterproperly. Check the drain pipe that the hose feeds into for clogs or debris.
5 Check the house's circuit breaker panel orfuse box. The circuit may have been tripped or a fuse may be blown. Replace anyblown fuses and reset any tripped circuits.
Thanks for visiting
Sep 07, 2011 | LG WM-2277HW Front Load Washer
I recently replaced the transmission, it now runs/agitates and spins but does not complete the spin cycle leaving the clothes wet. When th Spin only cycle is selected it does not engage
Replace the lid switch. Many models such as kenmore and whirlpool use mechanical
switches and they crack. The wash will still function but the spin will not function
correctly. (The socket is located under the control panel which hinges back after
removing the two corner screws) There are 2 philips screws and a 5/16 hex screw
holding the switch in. The 5/16 is a bummer to get to under the top of the machine.
The wiring is in a plastic channel clipped onto the chassis under the top panel.
Tilt the drum towards you to make access easier. Hope this helps
Jul 31, 2011 | Washing Machines
Settings wont change
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint tumble dryer model tdl62
you dont indicate if its gas or electric.
for both you may check the highlimit switch.
there may be two on ur unit depending on age.
they are located on the back panel and can be removed with a simple screwdriver. of course different models have different locations ..just poke around. (some are round disc others are plastic and both have a wire comming in and one going out of it) when they go bad they dont allow heat section of the dryer function (yea its a safety issue) if u have a meter test it, this should be a n/o switch if its closed...continunity (bad spellng) portion of the meter is used for this. simple check to do. you can do it with the machine off. email if you have more questios.
gl
k
Feb 27, 2008 | Washing Machines
WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the usual issues with this type of washer is the relay board located inside the top of the unit. as i remember mfgs make a nice unit but are not so good for sealing the electronics off from the rest of the unit. chances are some moisture is up in the relay or relay socket. easy access you will see several relays. pull and tag each as you do to avoid confusion. check for corrision build up on any part of this unit. this should help.. gl k
Jun 10, 2007 | Hoover AAA140 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
