Question about Toys
Edc man problem
00094-01 edc diagnose
My man tga tuck show this on dashboard edc 03779-10 what is the meaning
The following link provides the brief explanation of the error codes. The EDC code reported is likely related to the common rail fuel delivery system. It will likely take specialized equipment to diagnose the problem properly only available at a service center.
Hope this helps?
http://www.techtransa.lt/MAN_klaidu_kodai.pdf
Jul 04, 2016 | Toys
What is edc 03779
The fault cods EDC 03779,03778 have overlapping causes consist leakage of injectors,valve ,pipe but in some time malfunction in the high pressure pump , any one agree with me or there is any addition causes.
03779.....EDC ............ Rail pressure: Leakage in quantity compensation
03778.....EDC ...................Rail pressure: Leakage in overrun conditions
May 12, 2016 | Cars & Trucks
What is the meaning edc 03792-10 code. How can rectify. Man Tgx
Rohit, RE POST more info required, year,make, model #,etc and complete question.
show your appreciation by pushing the helpful button and follow me on Fixya for more tips and info.
Feb 18, 2016 | Cars & Trucks
My truck the light EDC its on how to fix
EDC is for electronic diesel control , which i expect you knew , so i would get the OBD codes read to pinpoint the sensor/switch causing the issue , can't be more exact as you faile to mention vehicle make etc
Apr 03, 2015 | Cars & Trucks
Edc 03779 what's prombelm this
The fault cods EDC 03779,03778 have overlapping causes consist leakage of injectors,valve ,pipe but in some time malfunction in the high pressure pump , any one agree with me or there is any addition causes. some people have solve the problem with changing the fuel filter.
May 10, 2014 | Cars & Trucks
EDC diagnostic 03779-10-
Rail pressure: Leakage in quantity compensation. Check the fuel rail for leakage.
Mar 30, 2014 | Bruder MAN TGA Container Service Truck
Scania v 480
refer to the Scania service department for the code readings interperation as they are specific to Scania codes.
Dec 14, 2013 | Cars & Trucks
I have a problem with my Man Truck TGA 33.360, Its showing alot of error codes on dashboard EDC 00959-01, EDC 00960-01, EDC 00961-01, EDC 00962-01. What could be the problem?
I have an answer for you.The codes are coming from a lost Tachometer memory.Yoour Edc Control Unit and teh Tachometer are not correctly aligned.You need to have th Tachometer reprogrammed.It has lost memory
1.EDC:00959-01 >seconds-Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
3. EDC:00961-01>hour- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
4. EDC:00962-01>Day- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
5. EDC:00963-01>Month- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
6. EDC:00964-01>Year- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
Nov 15, 2012 | Bruder MAN TGA Container Service Truck
Toys Logo
174 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
