Question about Microwave Ovens
NN-T553W microwave oven overheating
Microwave overheating
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
  • 4 Answers
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Posted on Nov 08, 2008
ginko
  • 19396 Answers
SOURCE: microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on May 21, 2009
  • 208 Answers
SOURCE: microwes panasonic nn-t553w
hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
Posted on Jul 16, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
Amana axp-20 overheated magnatron g2 error
this is generally caused by the magnetron overheating,you need to check the cooling motor for function and that the airways on the machine are not blocked as this is a commonly looked over reason for overheating magentron triggers.the other fault is a failed part
Apr 25, 2014 | Amana AXP20 25" Heavy-Duty...
Microwave heats up and shuts off and comes back on after a short time
The magnetron is overheating causing the thermal switch to switch off the system . The cause of the magnetron overheating could be of a dirty/faulty waveguide or magnetron.
Dec 04, 2013 | Magic Chef Microwave Ovens
Sharp carousel microwave oven overheating
replace unit.. it served it time and purpose
May 25, 2012 | Sharp Microwave Ovens
Maytag microwave overheated and shut off - Model #MMV5165BA
That is not good, the magnetron has gone, or the thermal fuse has failed, "protects the magnetron from overheating" There is a possibility the keypad control board was a affected.
Apr 07, 2012 | Maytag MMV5100A Microwave Oven
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
Microwave Problem:
It may have overheated. Wait 30 minutes and try again. I suggest contacting the manufacturer for repair or replacement. This unit is essentially new and should not do this.
Sep 08, 2009 | GE Microwave Ovens
Whirlpool Microwave, No Power
could be a damaged door saftey
Jun 14, 2009 | Whirlpool Microwave Ovens
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
Maytag microwave overheated.
There is a fuse that should be easy to get to behind the control panel.  Will need to take the grill off first to get control panel off.  Make sure unit is unplugged first.  There are high voltage parts in a microwave so you should have a professional do the work if you are not comfortable with it.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
