Question about Zanussi TC7102W Electric Dryer
No Heat - more info requested...
Hi all, I have now suffered this issue too where the dryer spins but doesn't heat. I have followed the steps outlined in previous posts and located both the heater and the thermostats attached to it. Now, the wires for the heater itself are crimped on and not easily removable and the thermostats are pop-riveted on, again not easily removable. I have run a multimeter across each item with the following results, can anyone advise if these are acceptable and if not which item is at fault and the best resolution please. Heater: (Three conections) Red - White: 38 Ohms Red - Black: 65 Ohms White - Black: 103 Ohms Thermostats (wire colours) Blue: 0.7 Ohms Red: 0.9 Ohms Many thanks Steve
Make sure berore working on your dryer that it is unpluged from the mains, also be sure it can not be switched on while you are working on it.There is a high limit thermostat in the front bulkhead, to locate open doar and either by feeling or looking you will find the termostat above the doar in the front of the drum.To remove undo two screws located in the bulkhead.If on test you find stat open circuit it will need to be replaced.
Posted on Oct 17, 2007
There is a high limit stat in the front bulk head.open door and you will find thermostat by feeling or looking above the door in front of drum
    Novelist:
    Champion:
  • 244 Answers
When u buy a new heater it should come with the stats and the wires to un-clip are on the inside not the wires that are crimped together follow the crimped wires which will take u to the plug which u need to undo u cant always go with what the ohms are 1 way you can test the heater element is by conecting a wire with a plug on 1 end but bare wires on the other place the correct colour to each other and plug this cord in and switch it on it should start to glow straight away if it doesnt then its your element m8
Posted on Aug 28, 2007
SOURCE:
Kenmore dryer 11062062100
If a dryer is not heating - and it is electric, then the first thing to check are the breakers. It runs on a double breaker and half of the breaker may be good (allowing for other functions other than heat). Half breaker will run motor and timer but the element needs both breakers (220v). If that is not the issue, then element may need to be inspected.
Apr 11, 2014 | Dryers
Dryer spins but doesn't get hot. Model #11077522600
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 73952 Gas Dryer
Dryer spins but doesn't blow hot air to dry clothes
heatman101-=
Aug 27, 2011 | Dryers
I have a Kenmore Stackable washer & dryer Model # 417.93702200 and my dryer will come on and spin but it doesn't get any heat to dry my clothes. what could be the problem? Where can I get the...
heatman101
Aug 19, 2011 | Dryers
We have a whirlpool duet dryer and it will not heat up. I've checked for blockages and there doesn't seem to be any. It does spin but no heat
heatman101
Jun 29, 2011 | Whirlpool Dryers
My ge dryer DBXR453EVOWW , drum doesn't spin, does heat
heatman101
Jun 12, 2011 | GE Dryers
Dryer will not heat but will run.
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wil not spin
May 08, 2009 | Dryers
Dryer not putting out warm to hot air. What is the issue?
May 07, 2009 | Dryers
My Dryer Will Not Warm Up Or Heat Up At All!!!
May 05, 2009 | Dryers
Zanussi TC7102W Electric Dryer Logo
116 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
