Hotpoint wmf760 aquarius
A terrible banging noise has recently developed on spinning. Is this the bearings? What can I do to fix it or do I have to get Hotpoint out? I heard this is a very common problem? Thanks
SOURCE: my hotpoint aquarius extra WMA36
AS A TECHNICIAN, MOST OF THAT KIND OF TROUBLE I ALWAYS SEEN THE TIMER CONTROLLER IS ALWAYS DEFFECTIVE. YOU NEED A TECHNICIAN TO LET IT SEE AND REPLACE THE NEW ONE. IF YOU DON'T, IT MIGHT BE THE START OF FIRE.KIM
Posted on Mar 16, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
SOURCE: hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Posted on Sep 30, 2009
barkencoa
  • 3463 Answers
SOURCE: Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Posted on Dec 05, 2009
Testimonial: "Great help. Thanks. I think I'll buy a pair of ear muffs"
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Posted on Jan 31, 2010
Testimonial: "Thanks for your help. In the end it was the front balance weight that had been gradually coming looser and looser and needed fixing pack into place."
Hotpoint 1200 wd62n banging noise when loaded but ok when its empty ?
There are many reasons that this could be noisy...
When you turn the drum (quickly) when it's empty does it rumble? Bearings, drum support or motor bearings.
If it sounds like a pneumatic drill when filled and spinning it could be drum support, bearings, balance weight or suspension.
These are not an exhaustive list but the usual suspects.
Jun 02, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Bearing making terrible noise when spinning is it easy to replace?
no ...its not easy to replace..there will be a problem in oil seal also.so that only water can go inside the bearing its better to replace a both oil seal and bearing
Jun 06, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Overloading of m/c.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius extra WMA36 is making a terrible banging noise whilst on final spin. When i open the door to take out the washing there was a smokey mist coming from inside the drum. Are the bearings...
hotpoint had a problem with the early bearings on these, so it would probably be the fault. or you may want to check the security of the concrete weights, one at the top and 1 at the rear of the tub.
Mar 16, 2008 | Washing Machines
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
