Question about Component Karaoke Players RSQ MKP-1000 Compact Karaoke player with Recording RSQ-MKP-1000
Starts being stuck on sequence - Component Karaoke Players RSQ MKP-1000 Compact Karaoke player with Recording RSQ-MKP-1000
1 have a 96 ford f 250 it runs when it is cool but wont start when it gets hot 9.4 eng
Temperature sensor is stuck on hot. It leans the fuel mix too much to start when hot. Sometimes this is called the "cold start sequence" that the engine needs to reset into for a rich fuel mix for starting.
Jul 18, 2017 | Ford F-250 Cars & Trucks
2000 Mercury Mountaineer won't start this morning. It's been freezing temperatures lately, what can I do?
Use a product like HEET. Have someone check the water temp sensor for being stuck on hot. Sensor must put vehicle in cold start sequence.
Jan 14, 2017 | 2000 Mercury Mountaineer
My 1994 mercury sable sametime wont start after is torn off.need same time to cool off and then start
Engine temperature switch is stuck on hot. You need it to reset to cold start sequence.
Jan 08, 2017 | Mercury Sable Cars & Trucks
Coleman evcon EB15A heat is stuck on. Thermostat disconnected to make sure it wasn't the issue. Stays on and heat blowing. What can I try?
It sound like your first stage sequencer is stuck in the 'on' position Shad. Usually the first stage is responsible for turning on the blower on low speed while energizing the first 5 kw of electric heat.
The problem you describe is typical of 'stuck' contacts within the sequencer.
No field service to the sequencer, replacement is necessary. Of course without actually seeing your furnace, this is just a resonably educated guess.
Apr 15, 2015 | Coleman Heating & Cooling
EXPEDITION STARTS UP FINE BUT DIES SOMETIME WAIT IT RESTARTS
There is a cold start "sequence" which is suppose to reset the engine controls as if you had a choke. This sequence is triggered by water temperature sensors on the engine.
This sensor is different from the one operating the dash gauge. It is probably stuck on a "hot" setting and the engine controls do not reset.
Oct 16, 2013 | 2000 Ford Expedition
Have a 3 ton 13 yr. old rheem.supplamental heat wants to stay on all of the time.were do i start.do have a lots of electronics and electrical experience.
the 1st stage heat sequencer is stuck(welded) closed use an inducted amp meter to determin the heater that is runing it will draw around 20 amps and follow the wire to the sequencer and replace it it will run the fan and 1st and 2nd heat elements
Jun 26, 2010 | Heating & Cooling
K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Apr 14, 2009 | Kenmore Dishwashers
M/b wont boot
Since this motherboard starts the boot sequence at all, then the next step I would recommend is to try testing it using a motherboard tester. This will help determine at which step of the boot sequence the motherboard stuck.
Flashing the motherboard's BIOS might help resolve this problem as well.
Apr 12, 2009 | QDI Group QDI Advance 10T Motherboard
Component Karaoke Players RSQ MKP-1000 Compact Karaoke player with Recording RSQ-MKP-1000 Logo
Top Component Karaoke Players Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Component Karaoke Players Audio Player and Recorder Expert? Answer questions, earn points and help others
