Question about Microwave Ovens
Mcc1010t magic chef micro/convection
Light comes on when door is opened , when closed the light does not come on and the turn table does not turn but the microwave heats cup of water to coffee degree, if the micro button is changed on yellow wire to when blue black the turn table turns but light still doe not come on ,sometimes the fan comes on other times not. thinking the two yellow wire from light might be in sink with micro switch. but I have no schematic to go by, need wire sceamatic,what could be problem??
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
mcc1010t magic chef micro/convection - bc0774ff-e2c7-40ae-9ef1-183cbf70e94c.gif
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Posted on Jul 13, 2013
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: MW 8115 SS Turntable doesn't turn
You probably have a stick door switch or broken door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
Posted on Aug 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Posted on Nov 27, 2008
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
Magic Chef MCC1010T reads out in celsius, not Farenheight.
you mud trsf you owner manual or download from www.retrevo.com
and proceed according.
God bless you
Jul 31, 2013 | Magic Chef Microwave Ovens
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
Magic chef micro key pad does not work
Try this site - It has answers to almost anything that can go wrong with a microwave, I know I read something there almost identical to the problem you mentioned:
http://www.repairfaq.org/sam/micfaq.htm.
Mar 24, 2009 | Magic Chef CMV1000B Microwave Oven
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
214 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
