Question about Refrigerators
Bosch KFN91PJ10A/02 ice maker won't work
After an outage of power our ice maker has stopped working. It feels like there is still ice in the tray but it is not dropping into the bin. I have tried to turn it off for a while then back on but that did not work. Everything seems to be working fine with the fridge apart from that. The water dispenser still provides sufficient water with pressure. Please help.
carldc3
  • 82 Answers
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
Posted on Jan 05, 2009
  • 10865 Answers
SOURCE: fridigaire side by side ice maker not dispensing
The auger does not have the strength to do it's job when a lot of ice is in the way. You can defrost the icemaker with a blow dryer. It will be messy so be ready with lots of towels or a mop.
Once the unit is dry, spray the auger with PAM or some similar cooking spray. Then let it recycle.
You can temporarily prevent more fresh water from entering the ice maker by simply moving the wire arm to the up position
Posted on Feb 10, 2009
I just fixed my daughter's frig with the same problem. The gear of both the box and the ice holder got water in the gear box and froze. This did not allow the gears to mesh and turn the auger. Clean the ice from both sides of the gears and try it. Works great now.
Rick
Posted on May 02, 2009
  • 1218 Answers
SOURCE: The ice maker was turned off for a few weeks and
Good day,
Nice explanation. Should join the club
Only two possibilities.
1. The water valve in the back failed.
2. A common occurance, is the water valve will leak a small amount even though not energized.
That water will flow down the fill tube but freeze before exiting the tube, and over an extended period, freeze a plug in the fill tube.
Inspect carefuly and be extremely cautious using heat. Lots of plastic and vinyl to be destroyed using a heat gun or hair dryer.
If that's the case, then clean it out, and check.
However, you still must replace that valve since the tiny leak could turn into a monster overnight or when your away.
Saw one of those create $18,000.00 damage to a house. Water under pressure is a dangerous animal.
Posted on Dec 13, 2009
  • 10865 Answers
SOURCE: The ice maker does not seems to dispense any ice.
The fix to your problem is to remove the ice, warm up the tray with a hair blow dryer and thoroughly dry it. Then spray it with PAM cooking spray which is an edible lubricant. After that dries, turn on the ice maker again and the ice will dispense. Joe
Posted on Mar 08, 2010
After power outage ice maker in rf4287hars stopped working,display is dimmed on off ice stopped working any advice
have an fridge technician check it out as it sounds like a control board problem from a spike that occurred after the power outage
Apr 08, 2015 | Refrigerators
We had a power outage and our ice maker just stopped working. Can it be fixed? thanks
If there was a power surge associated with the outage, maybe not.
Does the display still light up?
Dec 01, 2014 | Emerson Portable Ice Maker
Ge profile PFSF6PKXEWW AFTER POWER OUTAGE ICE MAKER DOESMN'T WORK
If the ice maker is not filling with water after dropping the last harvest of ice cubes it will indicate a defective WR57X10091 Water Inlet Valve If you would like to try self diagnostics on your model click HERE and go to page 78, I will be here should you have questions, Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
Our icemaker just stopped working. I can feel ice
You need to replace the ice maker. If you could send a model we could get you the exact part number for that.
Thanks
May 23, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
Dec 08, 2009 | Bosch Refrigerators
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Phil
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Dec 24, 2007 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
223 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
