Question about Dryers
Frigidaire caqe7011kwo lint keeps going out the hose going out side why
How do repair my front loader that is not draining
Mine had the same problem. I first checked the hose where the water drains out of the machine for clogs, lint. Then I checked the owners manual to find the lint trap. The lint trap was so clogged it burnt out the motor to drain the water. My Dad looked online and found the part number from the manual online then ordered it on the internet. The replacement only cost $113. Then a few months later water leaked about an inch all over my floor. I knew how to pop off the bottom panel. It turned out one of the hoses from the pump was disconnected. The clamp was loosened. I tightened the gasket around the hose with a screwdriver, then did a cycle, no leak. I also checked for any blockages in the hoses. The model I have is a little older, the newer models have lint traps that are easily accessible. I have a Frigidaire Gallery Series, model GLT----ending in 40FEI, sorry the rest is worn out. The trap is in the front on the right side, it is a black rubber container, attached with hoses and clamps. That is where I found the blockages due to cat hair, etc. Hope this helps. Taking off the bottom of the washer, it is a front panel, was a pain, 2 screws. I keep wood shims under the panel now so I can access it easier. I'm a petite woman, so it was quite a Job! Good luck. Hope this helps,a and made sense. Btw, they have manuals on the company website, PDF file.
Jul 29, 2014 | Frigidaire Washing Machines
Kenmore side by side refrider air vent on bottom not working
There is probably a fan under there to circulate air across the coils. If it isn't working, your refrigerator/freezer may have trouble keeping the temperature low enough. Check to see that the fan is clean of lint and dust and can turn freely (unplug the refrigerator before doing this, so it doesn't hit your hand if it starts turning). If still no luck, call a someone to come by and inspect it. The motor may need replacing.
Feb 26, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
I have a frigidaire dryer gler642as3 model it ran for two hours and didn't stop also when you open the door during the cycle it shuts the drum off but the dryer gets very hot you can't touch it what can it...
Well the timer could be defective. But believe it or not a clogged dryer vent can do some of the same things. Without air flow, the heater will heat, then when it doesn't circulate and and dry clothes, it gets hot and the hi temp overload near heater should turn it off, then when it cools it will start the same cycle over. Make sure you have good air flow coming out of the vent outside. If in doubt disconnect hose from dryer. Make sure to remove any lint. Put a panty hose leg over the hose and try the dryer. If it heats ok now, then you know your vent is clogged (panty hose will keep lint from spraying allover your laundry room)
Oct 28, 2010 | Frigidaire Timer Knob
Washer will not discarge water
Inside the tub to pump hose is a lint catching basket. Remove the bottom panel and get the hose off. Water will go every where so be ready. Dump out the lint, put everything back and retry.
Oct 09, 2010 | Frigidaire Washing Machines
Dryer is not getting hot and i changed the heather coil
did you notice alot of lint while changing the elements? if not and you can use a multimeter ck for open limit switch 240 volts to elements and voltage from thermal fuse on the side that goes to element to make sure you have 120 volts to the opposite side of element if inordimate amount of lint clean all portals for airflow i.e. vent tube motor housing vent hose and possible the vent cap
Jan 28, 2010 | Frigidaire FDE546RE Dryer
How do you clean the lint catcher
if washer having difficulties draining the water, check out the DRAIN MOTOR PUMP , IT COULD BE CLOGGED with LINT & debris, locate at bottom side is a small motor where 2 hoses are connected , AJ
Nov 22, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
AEG lavatherm T3
Try to dry clothes without the hose on Hose could be blocked. Jan
Feb 13, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Clothes aren't drying properly
look behind dryer is vent hose kinked or mashed flat? ck a load with hose completely disconnected may get warm and a little dusty but if problem solved reck hose all the way through
Nov 17, 2008 | Frigidaire Dryers
Frigidaire Full Size Laundry Center Model LCE-732L
inside the hot water hose is a lint screen, check whether it is blocked
not a solution ~60%
Sep 27, 2008 | Frigidaire Gellery Full Size Electric...
Dryers Logo
Top Dryers Experts
