Question about Dryers
Burning smell I smell something burning and i immediately turn it of
    Genius:
  • 1,617 Answers
It's your capacitor probably. Take a look at the black box next to the pull chain switch and see if it looks like it's expanding.
Posted on Jul 13, 2013
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Kodak 5210 all in one was working fine but all of the sudden it shuts off and now doesnt power on at all and smells as if something burnt out on inside
If you detect a burning smell, it's time to unplug the printer and replace it. Always unplug immediately whenever you have an electronic device with a burning smell as a matter of safety. As Kodak no longer makes inkjet printers, you will need to select another brand.
Hope that helps,
Bax
Sep 25, 2013 | Kodak ESP 5 Printer
Washer had just started and i started to smell something, and all of a sudden a noise came from the washer and then smoke came from machine really bad, the noise sounded like air escaping
Looks like something is short circuited & due to which there is burning smell coming out of the machine. Disconnect the machine immediately & inspect the insides of the machine. Locate the burnt motor or burnt wires. You heard the noise coming out of the motor. It could be dislocated brushes due to which the motor could not rotate & in turn it burnt your motor.
Sep 18, 2011 | Admiral Washing Machines
Washer stopped spinning and something smelled like it was burning
immediately turn off your machine and check the power outlet if there is smoke, pull out plug, maybe there is a short circuit, do not plug again, call a handyman or bring to nearest service centers.
May 05, 2011 | Admiral 32 cu. ft. Washer
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Burning smell when lights are on
If the smell is gone 24 hours after the lights were turned off, turn on the fan & leave the lights off. Check for the burning order again. If you can smell it replace the fan. It will be the armature shorting out in the fans motor
Apr 14, 2010 | Hunter Fan Company 5/1/1 Programmable...
Washed something too heavy, now washer does not spin or agitate, has burning smell
Burning smell is the precursor of fire. If you do not understand what that means.....Get a Techo out immediately and NEVER use the machine again until it is repaired properly. !
Oct 25, 2009 | Washing Machines
I have a 2005 chevrolet equinox the other day it started making this really loud sound like loud static coming from the speakers and the radio was off and you could smell wires burning can anyone help me
Yee gads! this issue sounds like something is shorted to ground, most anything of that type would broadcast into the radio.
Locate, immediately, the source of the burning wire smell. this issue is a serious FIRE HAZZARD. Do not let up until you find it. Burning wire smell, presuming that is what is happening, often results in major car fire... Find the burning wires and you will have your answer.
Sep 06, 2009 | 2005 Chevrolet Equinox
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Burning plastic smell in ViewSonic E55 monitor
Unplug it NOW and take it back to the store ASAP.
Mar 02, 2008 | ViewSonic E55 15" CRT Monitor
Dryers Logo
57 people viewed this question
Top Dryers Experts
