Question about AOMNI Corporation Televison & Video
How do i do a channel set up for my Aomni 50" tv
I dont have the remote control and the tv mode is on tv not cable i cant change it
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
Erik Seattle
SOURCE: My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
Posted on Apr 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: I lost the remote and cant find a universal that
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
Posted on Jun 06, 2009
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
How do I get my AOMNI TV out of hotel mode?
You need a SET UP Remote Control. That will take you to a menu where you can take it off of HOTEL MODE. I have one maybe we can help each other out. emailme
Dec 10, 2012 | AOMNI Corporation Televison & Video
Cant get cable tv
Hello
First connect the cable to its cable input socket at rear.
Turn the tV On and enter its Menu option window. Press UP or DN button on the remote control to select 'Cable'. Selecte EZ scan [channel search]. The TV must scan for all available channels, and will stop after all the channels has been stored in its memory. You have to wait till the search function stops; no other functions with remote cannot be done, and the set will not respond any external command, either by remote control or by its front panel control, except the mains power ON/OFF switch will work. OK.
Nov 21, 2011 | Zenith Z50P3 50 in. Plasma TV
I got a remote control for my tv cant change channel
Did you attempt to program the remote with the tv? Is it a universal remote? If so, most remotes come with a list of codes to try with most tv's. Does the volume work? Can you type in a channel direct... pressing 5 for example? If those work but not the up/down channel, the remotes faulty. Or is it set to tv or cable?
Sep 28, 2010 | RCA Universal Remote Control
I programmed my dish network remote to turn my tv on and off,and after I programmed it I cant change the channels on the satellite it just controls the tv. The remote has a 21.0 on the back of it and my tv...
You need to try a different code,505,506,516,523,526,566,573,612,627,647,652,653,654,655,656,658,659,664,665,667,669,670,679,680,704,717,730,738.....hope this was helpful....
Apr 25, 2010 | DISH Network IR Remote Control
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Tv tcl-14175 no sound on channels but ok on audio video mode
Hi
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
thanks!
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
Can't get the tv to move from the cable mode
Wondering if this is what your asking about, I cant find reference to Cable only mode...
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Aug 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Dvd hookup
  • First make sure the audio (red &black) and video (yellow) are plugged into their respective color matching inputs on the TV monitor.
  • Second either using the TV remote contol or TV's builtin control panel set the tuner mode to video. Depends on which TV's input terminal you connect the DVD player; that's where the Video mode has to be assigned.
  • For example: if you connect them to video1, set the tuner to video1. changing the channels up or down will never set it to video mode. You must press video button to change the tuner from regular channel mode to video mode.
Feb 16, 2008 | Televison & Video
Video mode
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
Jan 12, 2008 | Symphonic ST419E TV
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
Televison & Video Logo
21 people viewed this question
Top AOMNI Corporation Televison & Video Experts
cspassik
Level 1 Expert
Are you an AOMNI Corporation Televison and Video Expert? Answer questions, earn points and help others
