Question about Dryers
Kenmore gas dryer 110.78622700 Runs, tumbles, heats but does not heat long enough to dry clothes. Amy ideas what to check first?
  • Dryers Master
  • 8,220 Answers
Probably the solenoids on the gas assembly are bad. If it heats at all that is a sure sign of them heating up and quiting. Very common and easy fix. Before trying to check that look for sensor bars inside the dryer under the filter and clean em with windex. If the have buildup on em they might not be sensing wetness.
Posted on Jul 13, 2013
SOURCE: No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Posted on Nov 11, 2008
aborcass
  • 2651 Answers
SOURCE: gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Posted on Feb 12, 2009
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
milten1
  • 1304 Answers
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Posted on Oct 05, 2009
hunter19_46m
  • 7482 Answers
SOURCE: kenmore elite dryer runs but there is no heat, not drying clothes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Oct 26, 2009
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Dryer tumbles but clothes won't dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 10, 2011 | Kenmore Washing Machines
There is no heat when drying clothes. Dryer tumbles, but no heat. Open bottom panel, no glow from ignitor. Replaced ignitor. Still no glow.
It could be a high limit, thermostat, or thermal fuse...
if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 15, 2010 | Kenmore Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
Jun 02, 2009 | Kenmore Dryers
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
