Question about Fedders A6Y12F2D Thru-Wall/Window Air Conditioner
I am searching for the left side curtain/accordion and frame OEM# 787595 orpart #112400440002...where do I find this as I am not having luckc taylor
I have a 754 Taylor soft serve machine and the mix freezes up on one side in the bin
I am assuming that it is the left side that is freezing up? Is there a large disparity in temperature from the left side to the right? Your machine monitors the temperature on the right side hopper and that will determine the temp of both sides. If there is a large temperature difference between the two sides then it may be that you are low on refrigerant. You may have enough refrigerant to cool the left side but not the right side and since the machine only monitors the right side, it wont shut off the mix refrigeration system which could cause the left side to freeze up.
Dec 29, 2017 | Taylor Ice Cream Makers
Accordion blind repair and removal. bedroom blind in 396V on drivers side. strings are broke, and blind cannot be removed?
take it to an rv repair shop or a blind and curtain repair shop
it is installed as a unit so removal will be the opposite
it is the method that you will have to get advice on
Feb 04, 2017 | RVs
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
How to recognize why 339 raylor is not giving good product viscosity
If the machine runs and runs and can't satisfy your viscosity setting there is a refrigeration problem. The longer the machine runs the more the product breaks down, so you're problems get worse as the day goes on. It's not uncommon for these machines to lose refrigerant. I would guess that is the issue here.
You will need a refrigeration repair person to put gauges on the machine.
Here is some information I put together about the logic board adjustments on your machine. I think you might find this helpful.
Taylor Softech Control Boards
May 28, 2017 | Taylor Ice Cream Makers
How to find why 339-27 taylor not good product viscosity?
It could be a couple things. The most common is worn down scraper blades. Try new ones first. Worn scraper blades don't scrapers the cylinder walls and the ice cream that's stuck on the walls acts like insulation and it will take a lot longer to freeze this ice cream. If that doesn't solve the problem then you are likely low on refrigerant on that side. Your machine measures the viscosity by reading the amp draw of the beater motor. The harder the ice cream gets, the harder the motor works. If the ice cream isn't getting hard enough because of one of the reasons above, your machine wont shut off.
www.softserveparts.com
May 26, 2017 | Taylor Ice Cream Makers
Removing the windows on a 1994 Viper
The 1994 Dodge Viper RT/10 comes with side curtains, not windows. That is they are a see through plastic material sewed into a metal frame structure to allow for all weather use (not!).
Start by opening the door and locating a thumbscrew against the frame of the door post. Unscrew the thumbscrew and remove. It should have a rubber retaining lanyard to help you to not lose the screw. Once the screw is removed, push the window curtain toward the front of the car and pull up. There are two metal pieces that go into the door and latch onto a post inside the door. Reverse the process to put the window curtains back on.
May 12, 2013 | 1994 Dodge Viper
I received a Schylling Little Red Accordian with no instruction booklet. Can I get this?
This is a simple, real accordion. You could simply get a book or video on how to play the accordion.
Amazon Search Results: "How to play the accordion"
If it's brand new, you may want to contact where you purchased it from to let them know you did not receive the instruction booklet, which should have been included.
You could contact Schylling Customer Service to see if they can send you the booklet.
There may be good instructional information on the Internet as well. For example:
Google Search: "How to play the accordion for beginners"
Jan 11, 2012 | Schylling Little Red Accordion
Light leakage detected from my second hand PRO TL especially at low shutter speed (<1/15 sec). Details are as follows: a) appeared at lower third of a frame; b) spread out evenly from 3 points lying...
It sounds like the aux. curtain that covers the film when you're focusing either is not properly lowering, or is damaged somehow. You can remove the back and look through to see if you notice any light coming through. If you do, consult a tech. You'd only notice it on frames because mid-frames wouldn't remain in the light path long enough to be affected under most circumstances. It'd likely be a tear/nick in the curtain. Or, it could just not be completely be closing.
It could also be an issue with bad seals in the film back, or between the back and body, or even a crack somewhere in the back or the body itself. If you can't find a leak in the curtain, try keeping the dark slide in right up til you take a shot in, taking it out as soon as you're ready to shoot, replacing it before you wind, etc. to minimize the amount of time light could come from the anywhere but the back - to try and narrow down the location of the leak.
Jul 26, 2011 | Mamiya 645 Pro TL Medium Format Camera
Taylor 754-27 soft serve
Have u found a problem for this? if not let me know
Aug 06, 2008 | Taylor Ice Cream Makers
JUST BOUGHT A FRIEDRICH CP08E10 AND NEED ASSISTANCE IN INSTALLING THE FRAME CURTAINS. THANKS FOR THE HELP. USER242380@AOL.COM
Solution is: you have to secure 2 small plastic supports that comes with the set after you have attached the side curtains with 4 small screws that are included. You don't need any extra parts or stabilizer. Thanks.  user242380@aol.com July 29-08
Jul 28, 2008 | Friedrich Heating & Cooling
Fedders A6Y12F2D Thru-Wall/Window Air Conditioner Logo
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
