Question about Vehicle Parts & Accessories
MAZDA PROTEGE POWER STEERING
POWER STEERING BELT WILL NOT TURN
Loosen the belt & try turning the pump by hand,
to see if it seized
Posted on Jul 13, 2013
How do i bypass a power steering pump in a 2001 mazda protege without using a smaller belt
You can't. And I wouldn't do it for several reasons. First of all, it will be really difficult to turn the wheel at slower speeds and the reaction time of turning the wheels will be increased tremendously, thus increasing your chances of getting into an accident. Having no power steering assist on a car originally designed with power steering IS NOT the same as a car with manual steering. Second: many power steering racks require some form of recirculating fluid to keep the seals and the rack lubricated. So without the pump, eventually you might seize up the rack or blow a seal and that's a nice expensive repair.
Sep 23, 2015 | 2001 Mazda Protege
How do you tighten your power steering belts on a 2000 mazda protege 1.6l
you might have wrong belt or you need to make sure you are following the belt correctly where it needs to go. take a picture before you take off anything.
Feb 22, 2013 | 2000 Mazda Protege
Need a diagram for 1996 mazda protege serpentine belt
you don't have a serpentine belt just two drive belts one power steering and ac to crank belt and one alt belt
Nov 25, 2011 | 1996 Mazda Protege
When replacing the alternator belt on a 1999 mazda protege how many pullys does it go around. cause i dont know if this belt is to long
There are 2 belts. One goes around the Crankshaft. the Power Steering Pump and the Air Conditioner Compressor (if equipped) and the other belt goes around the Crankshaft, The Alternator and the Water Pump. You can have your local parts supplier verify that you have the correct belt for the vehicle by calling them and giving them the number on the belt. Also make sure that you are installing the belt in the correct position. i.e. putting the alternator belt on the alternator and not on the power steering, etc.
Mar 26, 2011 | 1999 Mazda Protege
How to remove a/c belt on a 2000 mazda protege
pretty easy, loosen the power steering on top and bottom, then there is a long bolt sideways on top of p/s pumy crank it in or out whichever loosens replace belt and repeat opposite steps to tighten
Feb 27, 2011 | 2000 Mazda Protege
Which bolts on the altenator and power steering pump need to be loosened to release the belts on a 2003 Mazda Protege?
I don`t know that there is a bolt to loosen the belt tension.There should be a automatic tensioner that you pull back and hold to remove the belt.
Oct 16, 2009 | 2003 Mazda Protege
How do you replace the alternator belt on a 1993 mazda protege? Do you have to remove the outside belt? If so how is that belt removed?
JUST LOOSEN THE BOLTS OF THE POWER STEERING PUMP TAKE OUT THE BELT FOR THE PUMP THEN REPLACE THE ALTERNATOR BELT AND STEERING PUMP.
Jul 28, 2009 | 1993 Mazda Protege
1994 mazda protege alternator belt
LOOSEN BOTTOM NUT ON POWER STEERING PUMP THEN REMOVE BELT
Jul 17, 2009 | 1994 Mazda Protege
My 2000 Mazda Protege DX has a tight steering. Can
Try turning the wheel when standing still with the engine running.
If it is tight check the obviouse, has the power steering belt come off. If not check if there is fluid in the steering pump resavour. If the belt is on and you have fluid you may have a bad pump.
I hope this helps
Regards
Sam
May 14, 2009 | 2000 Mazda Protege
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
