Question about Refrigerators
Magic chef counter top ice maker model: mcim22sv. Working great for a couple weeks then no sensor is not picking up that ice tray is full. It continues to make ice which builds up until there is no more water.
HVACRH20
  • 237 Answers
SOURCE: Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Posted on Dec 31, 2006
  • 1314 Answers
SOURCE: Ice maker not making ice
this is from another post i did but will cover you too your ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Posted on Jan 19, 2008
SOURCE: SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Posted on Mar 13, 2008
SOURCE: Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
Just had this issue - after checking all line connections, I pulled the ice maker feed water line from the back of the unit and found the tube was blocked with ice. Melted the ice with some hot water, and all is good once more. I would check for this before getting into the solinoid.
Posted on Jan 25, 2010
Sea Breeze
  • 4655 Answers
SOURCE: Ice maker is not working - sensor bar rolls up but
Sound like it is the dual water control only. Try filling ice maker with tap water and then let freeze. If after the ice in the ice maker dumps the cubes into the ice container and does not refill I would think the water control valve is at fault. I see your model had three different choices of water control valves and listed on this page=> Here and in right sidebar about 1/3rd down the page you will see three different water control valves. Here is your Service Manual=> LG LFX25960ST Stainless Steel French Door Refrigerator Try this test first because you mentioned no water in trays. Let me know what results you get and if you have more questions feel free to ask, Thanks, Sea Breeze
Posted on Feb 15, 2011
Suggest me a best portable ice maker that comes with three select able cube sizes?
You can get Ivation Portable High Capacity Countertop Ice Maker that comes with 2.8 liter water reservoir, 3 selectable cube sizes - yield of 26.5 pounds of ice daily. As this is one of the best portable ice maker that one can get for getting the best options for oneself. Also, this is best because it is made with many best features that are best for providing one with many benefits for the overall health of the body. You can also get many different options also that are available and you can purchase them after comparing them from Best Portable Ice Maker
Apr 01, 2017 | Refrigerators
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
How do you put water in the magic chef model number mcim22sv portable icemaker?
Remove ice bucket and add water to fill line at the back of the water tank
Jan 17, 2013 | Magic Chef Portable Ice Maker
The ice maker isn't working any more. It was making a clicking noise and no ice would fall into tray, now there isn't even the noise.
its just cheaper to by an aftermarket ice maker and replace it as its cheaper than repairing the old unit
Jun 30, 2011 | Magic Chef CTF1826AR Top Freezer...
Ice tray not filling completly with water.
Hi Mark, Unfortunately the problem is in your mind. Delusional thought processeses are a common manifestation of compulsive **** and liars. My advice is to get a new fridge and listen to a Bee Gees record backwards. Love Miranda
Jan 02, 2010 | Magic Chef Refrigerators
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
I have a counter top ice maker. I can't seem to locate parts or find out if this machine even exists. It stopped making ice last summer. It cycles but does't add water to the cube maker. You have to add...
Magic Chef Counter Top Ice Maker.
just bought one. it seems to go through the cycle, but i noticed no water is getting pumped up to the tray. I looked through the back and the water tu be is 1/2 way, doesnt seem to pump water up. I may take it appart soon. Anyone have any luck?
Mar 18, 2008 | Magic Chef Refrigerators
Refrigerators Logo
304 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
