Question about LG Side-by-Side Internet Refrigerator LRSPC2661T Side by Side Refrigerator
The monitor/tv does not turn on and i don't know how to fix it
The fridge works perfectly other than the monitor on the right door. The screen occasionally flashes a bright color for a split second. But other than that it does not respond to anything. The model of the fridge is the LRSPC2661T if anyone knows how to fix this or get it working again that would be great.
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
SOURCE: Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Posted on Jan 09, 2008
Mike258
  • 1498 Answers
SOURCE: Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Posted on Oct 30, 2008
angelo23
  • 53 Answers
SOURCE: Flatron W1934S screen has suddenly started to go bright pink
clean the graphics card first
Posted on Sep 06, 2009
  • 1684 Answers
SOURCE: lg monitor. Turns on but screen is white
This is a common problem on LCD monitors after a few years of use. Because of heat buildup in the monitor case parts called capacitors have started to blow out. When they blow they cause the power supply to fail and not provide the correct voltages the unit needs. If you go to our site at :
www.ccl-la.com we have pictures of what the blown capacitors look like. Open the back of your monitor and look for the blown ones. If you can solder then you can do the repair yourself. Unsolder the bad ones and install new ones. You will need Qty 2 1000uf 16volt and qty 3 1000uf 25 volt capacitors.We have a parts kit for $12.00 I will post a step by step repair guide for you on 11/29/09. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions please contact me at below address.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Nov 29, 2009
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
What does it mean when your computer says auto adjusting in progress, and its not the screen?
its on a dell monitor right
apparently these monitors have always had this problem some have'nt some have
no-one knows why not even dell
here are one post on how to fix the problem
Hey, I found a recent posting by someone else with the same prob----their solution seems to work (so far!)
Try this: click "turn off computer" but don't turn it off....your wallpaper turns the typical "gray" color in prep to shut down---on the monitor, hit the "plus" button to execute an "auto adjust"---do this about 3 times.......
so far, it works!
hope it helps
Oct 13, 2011 | Dell Computers & Internet
My acer Aspire 3500 wont turn on. It was fine a few hours ago but now wont boot. I keep getting the acer picture featurning the f2 set up and then the screen turns blank with a white flashing - in the left...
if you activity lights on, try connecting to an external monitor or modern flat screen tv. if the screen is flashing then it is probably a screen issue. eg the invertor r screen has failed.
Jul 23, 2011 | Computers & Internet
My Samsung SK01 42" TV
Power board assy' is defective. Check those bulging caps right into secondary circuit.
Jun 08, 2011 | Televison & Video
If I turn on my computer the monitor works well but after a few minutes it turns off itself (it goes to the standby mode orange led lights). Then if I turn on the monitor again it works only a few seconds....
Just in case the monitor is not te problem, why don't you try this.
For (xp)
-Go to desktop
-right click and click properties.
-screen saver
-power
-then set all the drop down list box to never
-click apply.
You can try it on other operating system.
-go to controls
-look for display and follow 2nd step on xp.
Hope this help. Thank you for using Fixya!
Apr 19, 2011 | AOC LM729 17" LCD Monitor
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
The monitor turns on and the computer image comes on for about a second then screen goes black again. The image that does come on is perfect.
I'm having the exact problem. I just got the new monitor & I replaced my 18". When I plug it in it flickers, when it does come on it's clear & clean; but after a few minutes it goes black. I tried to switch it to Digital & Analog, but I don't know how to fix it. I know it works, it was just plugged into my brother's computer. Is something wrong with the settings on my computer? If so, how do I fix it? I have both monitors hooked up on my computer desk right now, it's a bit crowded! PLEASE HELP ME!!!
Oct 22, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Loss of sound
i know a person who can solve this pro. 9426467211
Mar 30, 2009 | Bush WS6671 28" TV
No RGA input detected
through the Remote .. press menu .. and make sure that the VGA output is one that the Monitor can handle (if LCD 1280x1024) ... lower the refrech rate or definition until the monitor 'sinc's
Sep 26, 2007 | V-Stream Xpert 1280x1024 LCD TV Box...
LG Side-by-Side Internet Refrigerator LRSPC2661T Side by Side Refrigerator Logo
18 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
