We have the AF-351 plugged and ready to turn on but it doesn't turn on how do we turn it on.
    Problem Solver:
  • 10 Answers
Http://cache.air-n-water.com/manuals/newair-af-351-manual2.pdf read this manul might be of use
Posted on Jul 30, 2013
I need to get a water pump for AF-351 cooler
Sorry we do not sell parts or do we have the means to locate them for you.
May 18, 2017 | Cars & Trucks
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I need the fireing order for my ford bronco its got a 351 its a 95 i need a the gap for the spark plugs *** well
The firing order on the 351 that came in the 1995 Bronco is: 1-3-7-2-6-5-4-8
The spark plug gap should be on the emissions sticker under your hood, usually on the radiator support. It may also be on the underside of the hood.
If you cannot find the sticker, try a .044 gap, if that doesn't work go a little higher to a .052.
Jul 30, 2011 | 1995 Ford Bronco
Sharp AF-M808X air conditioner. suddenly there is only fan air movement. there is no longer any cooling; turning the thermostat knob to a higher level doesn't "kick in" the coolant. but...
Simple test: the thermostat in your unit is electromechanical - unplug the unit from the mains, take it out and measure the resistance between the 2 electrical contacts, if it doesn't goes to near 0 when you turn it even a little bit then it's defective and it will have to be replaced.
If the resistance does indeed goes to near 0 then the defect is in the AC system. Another simple test: open the casing of the unit and put your hand directly on the compressor; now turn the thermostat button. If it doesn't vibrate then the starting capacitor of the compressor has failed and it will have to be replaced with a similar one.If it vibrates then the cooling circuit has got a leak and all the fluid has been lost. For that you will have to call a pro that will solder the leak shut and refill the circuit with the appropriate fluid - only he will have it, it's not sold on the customer market.
Jul 22, 2011 | Sharp AF-M808X Air Conditioner
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Well i charge the battery and it works then when i turn it off and then go to turn it back on it doesn"t
lens need to clean throughly from inside and tight all AF unit and diapharm unit screws and try...
Aug 06, 2010 | Canon Cameras
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Aug 04, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Camera doesn’t start
The only solution that I found is to take off the battery from camera. After I reconnect the battery, the camera starts without any problem (lens are moving, LCD is on, AF is also on). The battery status is full.
Sep 12, 2005 | Samsung Digimax V5 Digital Camera
Heating & Cooling Logo
143 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
