Question about Brother MFC-5895CW Wireless Inkjet All-in-One Printer, Copy/Fax/Print/Scan
My Brother printer keeps jamming paper
My Brother MFC-5895CW printer continues to jam partially through the feeding process. When it jammed, I began pulling the jammed sheet from the front and it tore. I then opened the back and removed the remainder of the sheet. I closed everything up and tried printing again, but it jammed again. I tried a few times more with two successful feedings/printings, but since then every attempt to print has jammed. The sheet starts to feed, printing about an inch down from the page top, but then stops and I get a "paper jam" message. There is nothing obvious blocking the feed path. Any suggestions?
3 Suggested Answers
SOURCE: Brother Printer Jamming Issues
Do you have ink smudges on your paper? If so then you need to take out your roller clean it with alcohol really good and that should fix the problem.
Posted on Apr 18, 2012
SOURCE: paper jam
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Posted on Jul 13, 2013
Paper jam
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
What does error 73 mean? the display keeps giving that error... i have a brother mfc490cw
It is my pleasure to guide you.
The machine does not work due to a paper jam or some sensor problem.
Quote
Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feed Problem.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us" http://www.brother-usa.com/support/CustServ.aspx.
FAQs & Troubleshooting http://welcome.solutions.brother.com/bsc/public/link.aspx?faqid=faq000495
UNQuote
Good luck and please post back that you are successful or that I can be more helpful.
Jun 09, 2011 | Brother MFC 490cw Color Inkjet...
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
Paper jam-no jam
try doing a reset if that doesnt work is it under a warenty? if so then i would return it printers are tricky things to fix so many small parts
Jan 07, 2009 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-5895CW Wireless Inkjet All-in-One Printer, Copy/Fax/Print/Scan Logo
166 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
