Question about eMachines eM250-1915 Netbook
Insert boot disk - eMachines eM250-1915 Netbook
Post in the correct section
This is for automotive questions
Posted on Jul 13, 2013
Boot disk failure. Insert system disk and hit enter
Remove the CD player, open it and try cleaning the lens then put it back and try again if it doesn't ,convert the cd image to Flash disk using Rufus a free tool from the internet, then install your o.s using Flash disk.
Jul 17, 2016 | Microsoft Windows 2000 for PC
My desktop hp pavilion m7570n shows "disk boot failure, insert system disk and press enter" i opened monitor to check fr lose cables and just want to make sure if they are appropriately inserted. Please...
This can also mean that the operating system can not find the boot partition.
first check if in BIOS the right disk is the boot disk. You will have to push Del or F12 or other during startup. Check boot order. Choose your first harddisk to boot from and click F10 to save and exit.
If that is right and you tries all harddisks and still not booting, try to start up from a rescue disk or the original operating install disk.
for Windows:
given options: install on disk, tthen if already installed Windows found, choose repair. Choose repair startup.
Jul 25, 2014 | Computers & Internet
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Disk boot faliure please insert disk and press enter
Sounds like your hard drive has failed and became corrupted or the boot sequence is causing this on the motherboard. I reccommend entering CMOS setup if you can and changing the boot sequence to putting the hard drive first and if that doesn't work insert a recovery disk in during the disk boot failure...please insert disk and press enter screen. Jus make sure to press enter after inserting the disk if that is done...and if that fails I suggest replacing your hard drive with a similar one of equal value and qualities.
Jun 05, 2009 | Intel Motherboard
My pc won't boot up and there is message to insert system disk. I insert the disk boot up to the same message.
Take out all the disks from your computer drives and start up again.
If the computer prompt for a disk or OS, probably you have a HDD problem.
To get your CD drive available to boot...you must set that option on your PC bios (boot options menu)
Oct 06, 2008 | Computers & Internet
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
eMachines eM250-1915 Netbook Logo
15 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
