Question about Troy Bilt 5.5hp Self Propelled Mower
TB210 Drive Engage Cable. Can not remove Front Cover.
I have a TB210 that the self propelled drive engage cable has come off or broken. I can not get the front cover off to look at the cable. Can anyone help me? I have a picture of the cover. The mower is model number 12AGA26E011.
    New Friend:
Hi Chip, I too have a model 12AGA26E011 which has suddenly stopped being self propelled. I'm looking into how to remove the top cover so I can get to the belt and drive mechanism to determine what is amiss. If i have any luck I will let you know. obviously others that have posted here are stating the obvious but not answering your question. If you happen upon the solution please provide an update. Thanks! Doug
Posted on Aug 11, 2013
  • Doug McLean Aug 11, 2013
    Hi again Chip. After some more poking around, I found that there are 9 hex bolts that hold the cover in place. There are 2 on the top side situated near the wheels and top side of the mower deck. There are 5 more on the underside of the cover. 2 on the left side near the wheel, stradling the axle. Same for the right side. Then there is one more slightly left of the center point. the last two are under the mower deck where the blade is. I was able to undo 7 bolts, prop open the cover and put my belt back on the pulley. If the belt had snapped, I'm sure there would have been more 'undoing' involved.
4 Suggested Answers
  • 246 Answers
SOURCE: Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 202 Answers
SOURCE: Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Posted on Jul 06, 2009
SOURCE: Troy-bilt self-propelled won't engage drive
Make sure the drive belt that turns the wheels is in good working order as well. It may have detached.
Posted on May 02, 2012
The self propel system slowly stopped working and now doesn't work at all, what could it be?
You didn't specify the make or model of your mower, but generically speaking for self-propelled walk-behind mowers, the drive belt or the front wheel gears can wear out after several years of use. The drive belt could also be loose or off the pulley. The belt and the front wheels can usually be replaced.
You can remove the drive pulley cover and see if the belt is off.
The other components that make up the drive system are the gearbox and the engagement cable. Sometimes the cable can get get out of adjustment or come loose.
Jul 23, 2015 | Garden
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
May 02, 2012 | Troy Bilt 5.5hp Self Propelled Mower
My 650 series self propelled is not working. the propell engage cable still has tension but when I grip it to engage it does nothing. It doesn't make any funny sounds or any thing like that. The mower...
I believe your problem to be with belt adjustment. Your engage cable is apparently working because there is tension. Check end of engage cable where it attaches to tighten belt, check to see if belt is broken or close to being broken, or so worn down there is no grip left. You may need to replace belt or just adjust belt. I hope this will ease your up hill struggles.
Jun 14, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman self propelled walk behind lawn mower sef propel handle will not engage..the wheels will turn if you hold the handle down but the handle won't lock in........is something broken in the gear box?
Normally grass and debris are clogged under the belt/transmission cover, preventing the full engagement of the transmission cable/lever.
The cover is located on the topside, left front corner of the mower shell. Clean debris, try it again. If OK, re-install cover, If not, there is a cable adjustment (threaded portion with a nut on either side of a fastening arm) move the cable adjustment towards the rear, this will tighten the cable. Sometimes the cable assembly (includes the cable and the control box) needs to be replaced
Nov 08, 2009 | Craftsman Garden
The transmission will not engage
If the unit is between1998 & 2004 , the gears in the transmission may be stripped.To tell for sure, remove belt cover, start the unit & engage the drive. If the pulley turns & not the axel, the gears are stripped.
Aug 11, 2009 | Toro Lawn Mower With Toro Power Tools
My toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Aug 08, 2009 | Garden
Jul 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My Poulan weedeater self propell is not working.
Wanda, there are several things that could be causing your problem.
1) The belt could be worn out, remove the cover and check it
2) The drive cable could be in need of adjustment, engage it with the cover off and the engine not running it should be almost as tight as a fan belt on your car, if not try adjusting the cable
3) The drive gears inside the wheels could be worn out, remove the drive wheels and look at the drive gear teeth, excessive wear is obvious
4) Worst case scenario would be that your transmission is worn out
If all the above check out good, come back and post the model number, I will look it up and see if I can point you to any other possibilities but these are the most likely causes
Jun 13, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Poulan/weedeater self propell not working
if the drive cable is pulling back on the transmission and the pulley is turning but the axle isnt turning replace the tranny - no seperate parts available for tranny you must replace the entire unit
Oct 03, 2008 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
269 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
