Question about Franklin Industries FCR360D Refrigerator
Win i trun it on the top of the refrigerator gets hot
Top freezer frame is very-very hot, ice maker is not connected to the water supply. Is that could be a problem?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101';
Sep 07, 2011 | Frigidaire FRT21H8 Top Freezer...
When you open the freezer door the metal in hot to the touch
heatman101
Aug 29, 2011 | Kenmore Top Freezer Refrigerator
The top frezer fan is working and the bottom part is real hot and the freezer is working partially what seems to be the problem???
You need to look in the bottom cieling for a hole the size of a ballpoint pen. Take a small screwdriver(flat head) insert and turn clockwise ( it will only trun one way). You hear a clicking until the frige part turns off (fan and compressor). This is the defrost timer. It may run a few more months but they should cost less than most parts. If you turn it off or unplug and leave the freezer door open, it will thaw;then, will work about 10 days. Goodluck!
Aug 14, 2011 | Magic Chef Refrigerators
Why on the outside of the freezer is hot on sides?
heatman101
May 21, 2011 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator gets extra hot on top and side
The only thing that I can think of that would cause this is heat strips that are placed around the door frames to prevent moisture from forming around the doors. The way you have explain what is happening is an indication that the strips are out of control. If you can find the model number located on the bottom of the fresh food compartment door frame behind door get that for me. The problem is unsafe and should have your full attention until resolved. The parts cannot be replaced and can short out. If you have a local dealer or someone to talk to about the problem would be a good
idea. If you can find model number let me know. The model number above your post appears to be incorrect. Thank You Sea Breeze
May 24, 2009 | Whirlpool GD2SHGX Refrigerator
1995 Ford Windstar wont start win the cooling fans are on
If cooling fans are running then the PCM is not powering up. Check or replace the PCM relay in the under hood fuse panel
May 12, 2009 | 1995 Ford Windstar
Franklin Industries FCR360D Refrigerator Logo
20 people viewed this question
Top Franklin Industries Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
