Question about Frigidaire FER311FS Electric Dryer
Wiring schematic for fer311fso
Changed heating element but 4 wires came off the back the timer when the top of the dryer was leaned back
Master_Tech
  • 770 Answers
SOURCE: frigidaire dryer timer wires
I need your model number to look up the wires
Posted on Apr 05, 2008
SOURCE: wiring diagram
Had a three prong plug and now the new apt calls for a 4 prong plug...which I have but no diagram to show which color goes where.
Posted on Sep 16, 2008
  • 163 Answers
SOURCE: frigidaire front load elecrtric dryer runs but no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
dmftrucker
  • 1922 Answers
SOURCE: trying to change the heating element
take front cover off first, then top cover, then remove dryer drum belt and drum and replace element
Posted on Sep 25, 2009
hiltonjug
  • 612 Answers
SOURCE: need color code wire diagram for control wires on
This info should be located behind the control panel of your dryer. If not, someone must have removed, try asking again if it's gone.
Posted on Oct 19, 2009
Whirlpool Dryer IED4400SQ0 wont heat
Check your thermal fuse and the thermal cut-out fuse, two different fuses that can cause a dryer to run and not heat when open, or some dryers will not start when one of these has gotten too hot and opened....Usually caused by venting restriction of too much lint, common problem...........
A open operating thermostat or the high limit being open are also possible........;.
The other checks are live voltage checks, timer contacts, wiring, temp and internal motor switch......schematic is probably in back of control panel........
Takes some reading of a wiring diagram, understanding how to split the circuit ............Not for beginners.............Hope this helps...........do not forget to unplug dryer when doing anything on unit besides live voltage checks on circuits,,,,,,,,,,,,,,,
Mar 12, 2014 | Whirlpool Inglis IP8200 Dryer
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
May 18, 2012 | Dryers
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Sep 21, 2011 | Kenmore Dryers
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
Jul 31, 2010 | Whirlpool Dryers
Can I test dryer timer to see if its any good?
I do not think a "NO HEAT" problem can be caused by the timer.
Sounds like another electrical problem:
Have you check the house breaker or wall receptacle to see if you are feeding 220V to your dryer?
Have you check your hi-limit thermostat to see if it has continuity?
Those are the most common causes of "NO HEAT"
Aug 17, 2009 | Whirlpool LER4634J Electric Dryer
Changed high temp thermostats, maybe hooked wires back up wrong?
you should have a wiring schematic diagram somewhere on the machine otherwise the limit switches are normally wired in series w/element
Aug 15, 2009 | GE DVLR223 Dryers
Dryer not heating
look inside the control panel. sometimes they put the schematics there.
there should be two wires going to the heating element.
tnx 4 using fixya.
drcool
Aug 26, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire FER311FS Electric Dryer Logo
66 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
