Question about Measuring Tools & Sensors
HOW TO ASSEMBLE A STARRETT 818 AUTOMATIC CENTER PUNCH
HOW TO ASSEMBLE
How do i shut off my starrett electronic slid caliper?
Hello there
From the manual here
http://www.starrett.com/docs/other-downloadable-resources/798-electronic-slide-caliper-user-manual---form-951.pdf?sfvrsn=3
Automatic shut off of display after 30 minutes of non-use
Reactivation of display with movement of slide with no
loss of position
Sep 24, 2014 | Cars & Trucks
Starrett repair
I these punches are adjustable. Does the top turn or the bottom part turn. I use WD 40 or the likes to loosen mine up.
Jun 07, 2014 | Starrett 18a Automatic Center Punch
Need Starrett 682EMZ Saw Tension user guide
I can't find any available manual. I have an Starrett tension guide before but It was an old model and I don't even have manual for it. Did you try calling Starrett? They might can send you one.
Aug 13, 2013 | Starrett 682EMZ 60000psi or 4000kg per Sq....
Shut down starrett 733
On some Starrett calipers, there is no way of turnig them off, which means about once a year you have to replace the battery. sorry
Jan 22, 2013 | Starrett Electronic Caliper
How do I calibrate a Starrett model 449 depth micrometer?
Try the starrett web site. You can chat with them there about it. The adjustments are fair easy to do.
http://www.mytoolstore.com/starrett/micro029.html
Nov 12, 2010 | Starrett 50443 12 Machinists' Improved...
Popeil pasta machine off on switch just stopped working, where can i send for repair
No returns will be accepted without prior authorization. TO RECEIVE A RETURN AUTHORIZATION NUMBER call Ronco Inventions, LLC Customer Service Department.
RONCO INVENTIONS, LLC
21344 Superior Street, Chatsworth, CA 91311
(818) 775-4680, FAX: (818) 775-4665
Mar 10, 2010 | Ronco Automatic Popeil Pasta Maker
Starrett heigth gage instructions
Here is a link to starrett's how to read a vernier height gauge article
http://www.starrett.com/download/251_p122_125.pdf
Give them a call the parts department is very helpful and reasonably priced.
978-249-3551
Dec 27, 2009 | Starrett Measuring Tools & Sensors
How do you replace the bubble in a starrett 98 Level
Contact me at Starrett and I can email you the instructions on how to change the vial only if you want. The other option is to purchase a new tube and plug assembly (the silver tube with the vial). That is much easier to do. After, you can always send the old one in for repair. Third option is to send out the tube and plug assembly to be repaired.
Most people will change the vial only the first time, after that they go with option 2 or 3.
My email is pnault@starrett.com
Starrett Tech Support
May 04, 2009 | Starrett 50443 12 Machinists' Improved...
I´m looking for a product...
Prices range from $7 US to $30 US, depending on manufacturer and model. I bought one at Harbor Freight tools for $5.99 US. General Tool makes a good one for about $12 US.
The one you are looking at can be priced here for around $9 US:
http://www.sjdiscounttools.com/kti70002.html
Jan 23, 2009 | Omega Automatic Center Punch
Measuring Tools & Sensors Logo
26 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
