Question about Toshiba E-Studio 203SD Digital Copier
Set custom paper size Toshiba e-studio 203SD
Hi, the copier at work was working fine copying at paper size 8,5 x 16.- However earlier today it sticks to 8,5 x 14 for some reason, there is no 8,5 x 16 paper size on the settings menu.- Not to mention that every time that i make a copy a message pops on the screen that says: "Insert 8,5 x 14 paper Tray 1" which is annoying as heck.- Anyone know how to custom set the paper size to 8,5 x 16? thanks in advance.-
  • 643 Answers
SOURCE: wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Posted on Feb 13, 2009
SOURCE: Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Posted on Feb 18, 2009
  • 92 Answers
SOURCE: HPS Copy Machine; paper size settings not adjusting correctly, malfunction, misfeed in copier, repeat, repeat, repeat
there are user mode settings and also some have settings on the actual trays the little windw that shows the paper size on the tray open tray ther is a slot that a cut out plate with the paper sizes make sure the correct size is showing thru the window if not reach in and pull out the cut out and put back in with the correct size displaying thru the window 81/2 x 11 and R if your copying the long way hope this helps
Posted on Apr 28, 2009
SOURCE: my e-Studio 3510c doesn't have an
originals are what you scan using this copier, if you are printing on to 9 X 15.5 paper you must set the drawer (or bypass) size using the user function button then selecting drawer on the touch screen, I believe you will have to input it as a custom size but it should show X,Y coordinates on the screen to assist you in this. let me know if this helps or I can assist you further.
Posted on Aug 31, 2009
  • 643 Answers
SOURCE: My e-Studio 3500c copier has 4 paper drawers, and
Once u setup the drawer paper size, make sure u tick the update automatically on the printer driver properties. Otherwise the printer driver wouldn't detect the correct paper size.
Posted on Dec 30, 2009
Testimonial: "Thanks, the only problem is I'm not sure where I would update the driver properties at. Copier is password protected."
What can I do to remove system error [F5-02]
F5 02 Copy lamp lighting abnormality. Replace the copy lamp..
Sep 30, 2014 | Toshiba e-studio 203sd
How to change paper size in drower in toshiba e-studio166
press and hold original and copy button the light starts blinking on original side select the paper size by pressing original button and press start button once you selection is made.
Apr 23, 2014 | Toshiba E-Studio 161 Copier
It wont print on heavy paper
You may have to use the manual feed tray on the side of the copier. It is not designed to run through the paper tray, to many bends....Good Luck
Mar 08, 2013 | Toshiba e-studio 203sd
How do i get a meter reading on a Toshiba 203sd copier?
make sure the green light on the left side is set on "copy". ( you should see a list of copy, print, scan, fax). then press menu-> 3. after pressing 3 you should see the total # of copies.. press CA to exit.
Sep 20, 2012 | Toshiba e-studio 203sd
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
My e-Studio 3500c copier has 4 paper drawers, and one is set as LD (supposedly), but when we try to print to that drawer, it changes the paper size to 8-1/2x11 instead of legal size. We had a tech come in...
Dec 28, 2009 | Toshiba E-Studio 3511 Color Copier
My e-Studio 3510c doesn't have an ''original'' setting for printing on 9x 15.5 printer paper. How do I set a custom paper size setting
Aug 03, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 203SD Digital Copier Logo
67 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
