Question about Jack Lalanne Power Juicer (Stainless Steel)
Stopped working Humming not spinning
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
Motor is humming not working .. stoped in between juicer
it is jammed, or it is too full....stop, take apart, scoop out pulp, put back together and restart. go slow when juicing...too fast will jam it!
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Jun 20, 2010 | Breville JE900 Juicer
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
My juicer spins off of its axis i think, wobbles all over, spinning itself in circles spewing juice everywhere
Omega and Acme juicers will vibrate because pulp
is not ejected during juicing. Only suggestion I can
offer is avoid soft produce and feed as slowly and
as evenly as possible. Been using an Acme for 21
years and did notice a duller worn blade does produce
less vibration.
May 23, 2010 | Omega 1000 Juice Extractor
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
Unbalanced
TRY INSTALLING THE BASKET IN DIFFERENT
POSITIONS. IF THIS WORKS MARK THE
BASKET IN RELATION TO THE TOP MOUNT.
Jun 29, 2008 | Acme 6001 Juice Extractor
Cutting Blade won't come off
I do not have a tool so I used two pen tops, turned the blade counterclockwise while ensuring the filter basket stayed put. It worked well
Apr 16, 2008 | Jack Lalanne Power Juicer 250 Watts
Juicer stopped working
Fuse may be blown. Take off bottom, it is soldered to the circuit board. Unsolder and replace (I use a fuse holder) to make it easier
May 07, 2007 | Breville JE95XL Juicer
Jack Lalanne Power Juicer (Stainless Steel) Logo
95 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
Starnley Johnwells
Starnley Johnwells
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
