What causes odeamia in left leg and nee - Washing Machines
Indentation (whole not a sore) in left leg. I have been told by friend that is a sign of heart trouble.
Go see your doctor. They can examine the leg and tell you what to do. Seek professional help.
May 11, 2017 | Health & Beauty
What happened to House's leg?
He had an infarction in his right thigh. Similar to a clot that causes a stroke if it is in the brain, a heart attack if it is in the heart and an embolism if it is in the lung, an infarction in his leg blocked the flow of blood. House explains this in the "Pilot." It is further explained in "Three Stories" that his condition went misdiagnosed for three days causing severe nerve damage and muscle death. They wanted to amputate his leg but he opposed it. The surgery that tried to restore blood circulation and removal of dead muscle tissue left his leg permanently impaired and in chronic pain
Sep 04, 2016 | House M.D. (2004)
Why is there only edema in my left leg? what will a cat scan show?
Hello, I'm a ccontracted home health nurse from Long Beach Memorial. Having edema in just one leg is not uncommon at all, see it all the time! Just elevate that leg, no big deal. Now if you feel short of breath, may be a big deal ! if you have a heart condition, go to the emergency room! Your pending scan will show you abnormal structures within the body. In your case, they probably want to make sure you do not have a blood clot causing the Edema in your leg. Perhaps your blood vessels are just narrow. Hope this was helpful.
Dec 24, 2015 | Health & Beauty
Ive just replaced the fork seals on my non ABS 1990 st and noticed that one fork leg rebounds faster than the other. Is this correct and is this why the fork legs are of different inners?
Uneven rebound is caused by unequal volumes of damping oil in the legs or a broken or weak spring. Not sure why one inner tube is different, but it may mean the quantity of oil differs in the left and right forks?
I re-categorized to Honda Motorcycles for you.
Aug 24, 2015 | Honda Motorcycles
Dryer not turning on
YOU NEED TO CHECK THE BREAKER SEE THAT YOU ARE GETTING 110 ON EACH LEG OF THE BREAKER TO THE DRYER PLUG, OR JUST MAKE SURE YOUR BREAKER IS ON GOOD, AND SEE IF YOU HAVE 220 ACROSS AND 110 ON EACH SIDE OF DRYER RECEPTACLE, LET ME KNOE NEE TO DO THIS FIRST.
Jul 12, 2010 | Kenmore 63942 Dryer
I am having an oil leak and don't know how to go about fixing it. It starts as soon as I start riding the bike. It is coming from the left side of the bike and sprays on my pants on my left leg
Well, what kind of oil does it seems like, a thin oil or thick oil?
Have you clen the bike and see where it might come from. By description, can not be pinpoint source location, have you check your fork, oil cooler connections, or even your LH engine to trace it's source?
Because if you are riding and oil splashes onto your pant legs can be caused by air pressure blowing a leak onto your legs. Hunt the source fisrt then wil try to fix it.
Apr 25, 2010 | 1993 Suzuki GS 500 E
Tdc is not heating any more (dryer)
If it is spinning then you may have lost a 110 leg on your electrical outlet that causes the heaters to come on. Start there and work your way back to the dryer. You should have 110 from the ground(lower center hole) to the hot left hole. You should also have the same on the 110 ground to the right hot leg. if you check both the left and right together you should have 220/240 volts. If you don't stop right there and call an electrician. If you do have 110 on each leg as we call it giving you a combined 220/240 volts (it sometimes varies) move up the line to dryer. Either the heater coil has broken (good time to check for good airflow at the vent) or a non resettable thermostat has been tripped causing the heaters to stay off. Poor airflow can cause these two things to fail. The thermostat will need to be replaced if it is the non resettable type. The heaters may have gone too. Those should be checked as well.
Oct 16, 2009 | Hotpoint TDC32 Electric Dryer
My son's Xbox 360 has destroyed 2 games. It marks the disks with a concentric ring and renders the game useless.
The Rom nees to be replaced in this unit there is not quick fix here but rest issured its not going to cost a arm and a leg to do search for the part on ebay.com and good luck
May 15, 2009 | Microsoft Xbox 360 Console
Left legs doesn´t move right
i would take it back and get another one
Jan 07, 2009 | Mattel Hot Wheels R/C Bug Vehicle
Washing Machines Logo
Top Washing Machines Experts
