Sony mhc mecha error
The cd would not turn nor play.
5 Suggested Answers
junit80
  • 81 Answers
SOURCE: I have a Sony MHC-GX470 stereo...it will not play
the mechanism is bad or in human terms the motor that excepts and moves the disc has gone out i reccomend taking it to a repair shop to get a estimate because it may jus be cheaper to replace it.
Posted on Jun 26, 2009
  • 713 Answers
SOURCE: Have a Sony MHC-GX255 showing
replace fuse.
Posted on Feb 22, 2011
caroldon
  • 17130 Answers
SOURCE: Cannot open cd tray. Cannot
In some cases this is due to the main spindle getting jammed or there are mechanical errors which as mentioned needs a reset.
Also in some cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Posted on Jun 25, 2011
SOURCE: I have the sony mhc-gx450 and my CD player is
Most probably there can be two kind of issues (there is not enough data about symptoms) :
-either the lens is dirty / dusty : clean it with a special CD and cleaning product (the easiest, it doesn't require you to disassemble the player). If you are meticullous you can also clean it with ear-cleaner and a drop of windows cleaning product (you need to dismantle the player)
-or the drive belt is cut or loosen : change it for a new one (be careful : a new belt can seem REALLY short because it has to be tense almost to its maximum. If you use a wrong belt -a bit too long- it will slip). symptoms : the drive doesn't fully eject (or at all), or the drawer can't completly get back. The motor can't mount inside the CD hole.
Posted on Jun 26, 2011
In my sony home theatre MHC - GZR88D i want to play music as dvd , usb ,etc.... ,don't played only one word is shown that mecha error , what can i do
Probably means there is something wrong with the DVD drive. Check that a disc is not inserted wrong. You could also try cleaning the DVD lens.
Jun 28, 2015 | Sony Audio Players & Recorders
Sony mhc- rg 55 MECHA ERROR disc spin then turn off
My mhc-rg 55 shelf system reports a Mech error when I turn it on (after rotating the CD tray to try to take up each CD twice ) Then is shuts down.... I took the unit apart and saw noting obvious... (Of course it was more difficult to reassemble and still doesn't quite fit properly.) But the problem persists. Looks like it over to the repairer. Sorry - No solution here
Nov 21, 2012 | Sony MHCEC99 Mini MP3 hifi system Shelf...
How to fix mecha error on sony mhc-gx555
https://us.en.kb.sony.com/app/answers/detail/a_id/38877/~/the-stereo-system-malfunctions,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Why My sony Mini Hi-FI MHC-GZR88D says Mecha Error
How to resolve mecha error in sony mhc-gzr88d
Oct 08, 2011 | Audio Players & Recorders
Cannot open cd tray. Cannot rotate cd's. Plays only one cd and intermittently. Get 'mecha error' message. Had similar problem last year without 'mecha error' message, which was...
Jun 25, 2011 | Sony MHC-RG290 Shelf System
I have a Sony MHC-GX470 stereo...it will not play cd's...when you load a cd in it comes up with "mecha error"...the cd changer will not move between cd 1, cd2 and cd3 either.
Jun 26, 2009 | Sony MHC-GX470 Shelf System
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
Jul 20, 2008 | Sony MHC-GX450 CD Shelf System
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
"mecha error"?
i've dismantled my system found the top fuse had blown on the transformer also aligned the cd tray all works sweet now wahoo :)
Feb 11, 2007 | Sony MHC-RG660 CD Shelf System
13 people viewed this question
 Grubhead
Grubhead
