Question about Microwave Ovens
721.89941490 no power to oven, plug checks out OK. Help?
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Posted on Jul 13, 2013
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
No power to my microwave
first check the mains power chord for continuity and open circuit.
if this is ok then check the input voltage .(either 110V/220V)
Check these and tell me .
Mar 27, 2014 | Whirlpool MT4078SKB / MT4078SKQ 700 Watts...
No power at all
check plug fuse,if thats ok,there should be another fuse inside on the power supply have that checked out
Aug 14, 2011 | Bosch 500 HMB5050 Microwave Oven
No power to unit. Internal fuse ok. Power ok to plug
It sounds like you have a short in the keypad controller system, there is a microprocessor board mounted behind the the keypad that control vital areas of the microwave's operation. I suggest appliance technician to check out the systems hardware and the rest of the oven.
Jan 31, 2011 | Kenmore 80603 Stainless Steel 1100 Watts...
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
NO POWER GETTING TO MICROWAVE, CHECK POWER PLUG IT WAS OK
Hi,,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 24, 2009 | Sharp R-1480 Microwave Oven
ALL POWER LOST
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The parts I would suspect most are the internal fuse, the magnetron TCO (thermal cutout) or the oven cavity TCO.
To check or replace the latter, you'll need to remove the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 26, 2008 | Microwave Ovens
Whirlpool microwave oven
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It says:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
If for some reason your tech sheet is not there, you can download it here.
We regularly repair control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 30, 2008 | Whirlpool GH4155XP Microwave Oven
Microwave F-7 Code
F7 is q Power to magnetron
interrupted
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
