Question about Porter Cable Garden
Portercable Pressure Washer Model PCH2401
I have this pressure washer and it stalls the motor out a after using for 10 minutes or so. I tried to start it again and it was hard to pull.I disconnected the water supply and it started up right away. I noticed the pump was very hot.I connected the water supply again and it ran for a little and shut down again.Pump hot again. This unit as a thermal relief on it could this be defective causing the pump to heat up therefore load the motor down and causing it to stall out. The pump on this washer is ANNOVI REVERBER MODEL NO. SJV2.5G27-1 Any help would be appreciated
    Top Expert:
  • Porter Cable Master
  • 50,084 Answers
When the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Posted on Apr 25, 2017
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 15 Answers
SOURCE: builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Posted on Apr 23, 2009
SOURCE: Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
Posted on Sep 01, 2009
  • 2841 Answers
SOURCE: New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Posted on Apr 25, 2010
On my brute 2500 psi pressure washer when I let go of the trigger it kills the motor. I changed the unloader valve and still does it . Any suggestions? Thanks
Excessive pressure can stall out a motor. Try reducing by adjusting unloader valve. Clockwise turn will increase pressure, counter clockwise turn will reduce.
Oct 30, 2016 | Garden
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
Pressure washer shuts off overheating
If you are using an extension cord this will happen. If using an extension cord make sure it is a 12ga.If you are not using an extension cord then it could be a bad motor or low voltage from the source.
Apr 19, 2014 | PowerStroke 1700 PSI Electric Pressure...
The washer works for approx 10 minutes, then cuts out for approx 10 minutes. Any ideas so I can order the parts?
I am assuming this is electric powered and if so your motor is overheating and cutting out. There are many reasons why this can happen. Does the motor sound slow or underpowered from when it was new? If so you may have lost a field coil so only 50% of the motor is working, you will also notice a drop in pressure as well. If not then it could be the bearings in either motor or pump head (should make a whining sound though). A failed bearing will mean the motor working harder and overheating. It could also be the pressure valve sticking or the spring inside has broken and doesn't allow pressure to build so the motor runs faster and then overheats...
Mar 07, 2014 | Garden
Pressure Washer
any leaks from connection at pump to gun and wand assembly if so the valve is detecting leakage and open up again without u squeezing trigger it builds up in the head.if your trigger gun is leaking internally then you will need to replace the gun this unit uses a trap pressure unloader valve
Jul 15, 2013 | Garden
Stalling pressure washer
Make sure you have a strong water supply going into it. On the two I have owned, they would struggle and the motor would "rev up" quite a bit if there was even a slight kink in the supply hose, or if the tap wasn't opened all the way.
May 18, 2012 | Craftsman 2500 PSI Briggs & Stratton...
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
Builds up to much pressure in hose and stalls engine
Mar 16, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Garden Logo
76 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
