Question about Plumbing
Valve knocking sound
We have a relatively new Hudson Reed thermostatic valve with outputs of which only 2 at a time can function. It was running fine for about a month and suddenly it will start making a banging noise. Turning off one of the 2 outputs works most of the time (doesn't matter which one) but so does turning it off completely waiting a second and turning it back on. Any ideas what the problem could be? We have 65 PSI and the unit is rated from 2 to 75 PSI.
  • 7,733 Answers
I think the lines are clogged.
Posted on Jul 16, 2013
  • 68 Answers
SOURCE: Bath tube plumbing is making vibrating sound then shutting off
Replace the cartridge even if its new. The vibrating is from the internal workings of the stem. It also effects the volume of water.
good luck, Phil
Posted on Dec 11, 2008
  • 25 Answers
SOURCE: moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Posted on Jan 04, 2010
Biodgr8able
  • 18 Answers
SOURCE: Turning on this faucet, hot or cold, results in a
I would take the aerator off, and turn faucet on to see if the same thing happens. the aerator screws on the very end of faucet were water comes out. You may need channel locks to loosen, If your worried about marking up the aerator with scratches, then hold a cloth around aerator to protect the finish. Do not squeeze to hard with pliers. If there is a constant flow now with the aerator off, then your problem is a clogged up aerator. Disasemble, laying pieces out on table the same way they came out for proper reassembly, after cleaning.
Posted on Jul 02, 2010
  • 10 Answers
SOURCE: just received a service kit
yes
Posted on Feb 23, 2011
  • 112 Answers
SOURCE: I recentlly had a Danze model # D11200BT installed
You have what is called water hammer effect going on the water pressure is to high this can cause problems with all you plumbing fixtures. You need to have a water hammer arestor install or put a main line pressure reducing valve in.
Posted on Jun 13, 2011
Hudson parts for 30161 sprayer where to buy
Direct, eBay, Amazon.
To speak with an expert, please call 1-800-9-SPRAYER
and someone will assist you with your inquiry.
Product Search ' H. D. Hudson
www.hdhudson.com/product-search
Hudson® Universal Maintenance Kit Model 6972. One Kit Repairs over 90% of Hudson Sprayers with Genuine Sprayer Service Parts! 6972 Hudson® Universal Maintenance Kit. View Product Details ...
HD Hudson: Home
www.hdhudson.com/ HD Hudson Manufacturing Company is the world's leading manufacturer of innovative, high quality, consumer and commercial sprayers and sprayer systems.
Product Details ' Hudson® Universal Maintenance Kit ' H. D. Hudson
www.hdhudson.com > Product Search Simple parts kit offering - one kit repairs over 90% of all Hudson® sprayers! Contains necessary parts to rebuild the majority of both metal and poly sprayers. In most cases, kit will upgrade existing components on customer's sprayer; Contains Viton® O-Rings, TOV™ Thumb Operated Valve, Pic-A-Pattern™ Fan/Cone nozzle ...
Product: Hudson Eliminator Sprayer - 1 Gallon, Model# 30161
https://www.northerntool.com > Sprayers > Handheld Sprayers Item #268137 is no longer available. Hudson Eliminator Sprayer - 1 Gallon, Model# 30161. Find Similar Items. Replacement Parts Available. More Info · Find Parts ...
Hudson Pump Sprayers Parts: Amazon.com
https://www.amazon.com/slp/hudson-pump-sprayers-parts/2naarhymmyr79cg
Buy products related to hudson pump sprayers parts and see what customers say about hudson pump sprayers parts on Amazon.com ? FREE DELIVERY possible on eligible purchases.
H. D. Hudson Manufacturing Company Online Store
hudson-sprayer.com/ COMPRESSION. SPRAYERS. ? Locate Sprayer Parts · ? World Health Library · ? Newsletters. This equipment has been found to comply. with the performance guidelines of the. World Health Organization Specification. number WHO/VBC/89.970.
Hudson Sprayer ' eBay
www.ebay.com/bhp/hudson-sprayer Find great deals on eBay for Hudson Sprayer in Find More Garden Tools & Equipment. Shop with confidence. ... Hudson 62062 Bugwiser 2 Gallon Sprayer Galvanized Steel,No 62062 Hudson, H D Mfg Co 62062 029925620629. ItemWeight: 5.59. ... Hudson Brass Extension Wand with Nozzle Trigger & Parts Set. $18.00.
H D Hudson Sprayer Parts - Sears
www.sears.com/search=h%20d%20hudson%20sprayer%20parts Items 1 - 37 of 37 - Hudson H. D. Hudson Manufacturing Company H. D. Hudson 96302E H. D. Hudson Comando Sprayer, 2 Gal, 18 in Extension, 42 in Hose 96302E Pack of 1 · 0 · Sold by SIM Supply · Hudson H. D. Hudson Manufacturing Company H. D. Hudson 20012 H. D. Hudson Multi-Purpose Poly Sprayer,. $31.13 ...
Hudson Sprayer: Amazon.ca
https://www.amazon.ca/slp/hudson-sprayer/e675o8k2yzys3u8 Buy products related to hudson sprayer and see what customers say about hudson sprayer on Amazon.com ? FREE DELIVERY possible on eligible purchases.
Hudson Universal Maintenance Kit
Apr 07, 2018 | Coffee Makers & Espresso Machines
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
Hi Have a hudson reed kia twin valve shower - fab! But recently taking forever for the hot water to come through. Don't think it's the boier as the hot water comes through quickly everywhere else...
with out a water circulator every thing takes time ----------- sounds like the thermostats going bad you do have a 10 year warranty on this faucet type in your browser hudson reed kia faucet
Jan 18, 2011 | Home
I have a craftsman 1hp 4 gal compresor. It's not building pressure and air is pumping out of the air filter not in???
sounds like reed valves are bad,sometimes you can take the reed valves and flip them over for short fix,best to put new one in unit.
Jun 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
My Hudson Reed lift and turn mono block tap leak
There should be a retaining ring right under the handle when removed. The stem of the ball runs up through the middle. Tighten this retaining ring and it should stop the leak.
Mar 21, 2009 | Hudson Reed Traditional 6 piece bathroom...
Plumbing Logo
37 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
