Question about Dell Dimension 4600 PC Desktop
Reformatting pc Can you please tell me how to reformat my pc as I've removed everything and tried rebooting with Windows XP disc and it doesn't work
  • 95 Answers
This how you reformat a dell computer,
Firstly remove all external devices. i.e printer, scanner
  1. Then turn on you system
  2. When the DELL screen appears press and hold "control" on the keyboard, press the "F11 key" then release them both at the same time. "DEEL PC RESTORE BY SYMANTEC" will appear.
  3. click restore button
  4. then click on confirm. (progress will take 8 to 10 minutesto complete) When the restore is complete. The message "THE SYSTEM RECOVERY PROCESS WAS SUCCESSFUL" will appear.
  5. Click finish button. The computer will now restart. The system will be how it was whnen it was first delivered.
Once this is done I would suggest doing a windows update.
Posted on Mar 16, 2008
    President:
  • 2,961 Answers
What you need to do is put the XP cd in the cd or dvd drive first,then, when the pc is booting up press either F2 or Del depending on bios and the cmos setting screen will appear. Go to advanced cmos settings and the top line normal reads 'first boot device, this will be set at HDD or hard disk, this needs to be changed to cdrom. When you have changed it, save settings and exit, the system will now reboot and an option to boot from cd screen will appear, you then press Enter to boot from cd then follow the instructions to format or install windows.
Posted on Aug 27, 2007
6ya staff
SOURCE:
Stop:0x0000007B error occurs when formatting the windows xp
It sounds like a boot sector virus, hardware issue or registry issue. When reformatting make sure you delete existing partitions and create a new one. Also if your trying to downgrade microsoft windows doesn't allow it. You will have to use gparted live cd and completely format the drive then try reformatting. for more info contact me at [email protected]
Oct 04, 2012 | Dell Microsoft Windows XP Home Edition
How ca i format the pc
Try running the check disk utility instead of reformatting and reloading everything.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
If all fails and you want to reformat as your say, just reinstall windows, it will reformat and delete everything for you.
May 21, 2012 | IBM (74P1644) Motherboard
I removed the samsung hd501lj from a buffalo drive enclosure and installed it in a windows xp machine, I can see the drive in disk management, but can't assign a drive letter
You need to prepare the drive for Windows. This unfortunately usually means reformatting. You should be able to tell it to reformat and prepare the drive from the disk management console if you right click on the disc.
Apr 07, 2011 | Samsung SpinPoint T HD501LJ 500 GB SATA...
How can I reformat my A20m IBM Thinkpad..
Doing a Format on your PC Should Be A Last Resort! Reformatting your Windows computer is usually the absolute last resort and is often done unnecessarily. Before you go through the process of doing a reformat of your hard drive please take a few moments to read through the rest of our website. If you are reformatting to fix problems with your Windows computer it's possible that by using some of the tips on our site, or by downloading or purchasing some of the tools or products that we link to, you might be able to avoid the need to reformat your computer. Because doing a complete reformat of your computer will erase the contents of the hard drive and require you to reinstall all software, reformatting is usually a last resort. Some Computer Manufacturers Make Reformatting Easy Many name-brand PC manufacturers include a restore-disk which makes it easy to reformat your PC and return it to the state it was in on the day you purchased it. Some manufactures supply only a standard Microsoft Windows CD, and some (usually lower-end PC manufacturers) supply neither! If your PC did not come with a restore or reformatting CD, then you will need to take extra steps to format your hard drive and get Windows re-installed. Back Up Your Files Before You Reformat your Windows PC!Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
Things to do before you reformat your PC hard drive
  • Write down or print out all notes and internet pages because once the format process begins, you will no longer have access to them (or anything else in the PC)
  • As already stated, BACKUP all important files and data! When you reformat your computer everything will be erased!
  • Make sure you have all the CDs and other software. All programs will have to be reinstalled after you format the hard drive. Don't forget about software that came with hardware such as printers, scanners, etc.
  • Write down the brand and information for all the hardware on your computer. Look in the Device Manager and make note of the brand and model of network adaptors, video cards, sound cards, printers, modems, and displays. After reformatting you might need this information to reinstall drivers.
How To Reformat your Windows XP PC If you're ready to take the plunge and format your computer Click here for step by step instructions to reformat your PC.
Security tips: How to prevent viruses
Guide From:
http://grownupgeek.com/reformat
Apr 13, 2009 | IBM ThinkPad T30 2366 Notebook
Reformatting E-machine desktop computer W3115
Insert the CD to the CD ROM. Set the bios setup to boot using the CD-Rom. Space bar while booting up. If you got the setup press F8, choose NTFS to format the drive. Then go on with the Installation.
Mar 10, 2009 | E-Machines eMachines Desktop PC
Virus
Don't reformat it just yet. Tell us what OS you are using, and I can try to help.
I will assume you are using WIndows XP or Vista - what you can do, assuming you have kept your PC up-to-date, is try to run the inbuilt Microsoft anti-malware program.
Click Start, Run, type MRT and press Enter or click OK.
You should get the February 2009 version of the Microsoft Malicious Software Removal Tool.
Do a quick scan and see what comes up. If anything is found, reboot and repeat the process doing a full scan (can take several hours).
That should fix and remove the most common virus infections. Let me know how you get on.
If you still need to reformat, you need to use the Dell recovery CDs that came with your laptop. These were a blue recovery/drivers CD and a purple CD for Windows XP sp1 or a green CD for Windows XP sp2. Not sure about other versions of Windows. There is no magic button to reformat with Dell laptops.
Feb 16, 2009 | Dell Latitude D600 Notebook
How to reformat ASUS Eee PC 900 notebook?
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
Jan 13, 2009 | ASUS Eee PC 900 Notebook
Reformating my gateway E 4100
reformatting a drive is a big undertaking, formating the drive will erase everything, including viruses, before you format you need to make sure you have all the discs including the windows disc, driver discs, and a factory restore disc, also you make check the documentation on your system because alot of the gaetway, dell, emachines systems have restore partitions installed on the drive. Also youll need alot of coffee and alot of time, most importantly aside from the windows disc youll need a driver disc for any ethernet or wireless card you have installed. without this you will not have access to the internet most likely and donloading updated drivers is very helpful. This is a time consuming proccess unless there is a restore partition on the harddrive, the documentation will tell you how toaccess it if it exists, if not a restore disc will be nice.
Dec 13, 2008 | Gateway E-4100 PC Desktop
Desperately need to fix my laptop
Yes this can be fixed however it will require reformatting the drive. If you have any vital information on your laptop take it to a professional as you will not be able to recover after you proceed.
Use any bootdisk (Ubuntu, XP, Disk commander) that you have at your disposal. Assuming you still your XP disc, change your BIOS to have the CD as the first boot device. If you have a proper XP disc (non-OEM) it should display a blue setup screen that will disappear after a few minutes. Then press R to enter Recovery Console, press 1 and then enter. Type fixmbr and press enter, then press y and enter again. Type exit and enter, the computer will reboot. Now follow through the install process.
Jun 15, 2008 | Compaq Armada M700 Notebook
Reformat/Reinstall Refresh on hdd
You should provide either CD/DVD rom to boot your sytem in bootable disc.
And you should provide windows XP/2000 bootable disk.
You will need:
CD/DVd Rom
Bootable windowsxp/2000 to reinstall your system.
Note; reformatting or reinstalling your system all files will be remove. you should back up important files before doing.
Jan 14, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
132 people viewed this question
Ekse
Clive
Clive
Alun Cox
