Question about Samsung Computers & Internet
Bios boot options
How can i get the Samsung WriteMaster to show up on the Boot options on the BIOS
    Sergeant:
  • 376 Answers
If it's an internal drive, make sure the Master, Slave, CS jumper is on the correct pins. If it's an external drive, make sure the usb port(s) are working in Device Manager.
Posted on Jul 06, 2014
2 Suggested Answers
  • 5 Answers
SOURCE: booting with usb dvd writer ? my pc bios have usb cdrom option
No it is not good for that.
Posted on Jan 23, 2010
My cd-dvd drive is not showing up as a boot option in the bios?I recently upgraded to windows 10,or i attempted to ..no success? I need to boot from my cd so i can recover windows 7..
Most BIOS have a key to let you choose what to boot from (F10 or F12 or somethinbg). If that does not work, try hitting F8 on startup for other boot options. Also, maybe go into the BIOS and there might be an "auto detect drives" feature. Good luck.
Jan 10, 2018 | Option Computers & Internet
Samsung 350v5c blue screen, no signal & won't boot
I would recommend resetting your BIOS back to the defaults.
  1. Turn your computer on and use F2 to access the BIOS.
  2. Using the arrow keys, navigate to the Exit menu.
  3. Look for the option (or similar) Load Defaults and press Enter.
  4. Press F10 to save and exit the BIOS.
  5. Your laptop should revert to the default BIOS and boot order settings.
Jul 08, 2015 | Samsung Np350v5c 15.6-Inch Laptop Silver...
Boot options
2 things you may try, 1? try to push f2 or del to get into the bios and modify the boot order of the devices or 2? press f4, f8 or some f(X) that usually show you boot options, this options may be shown on your screen when you turn on your computer and do the post, just pay atention to see if you find them.
Jun 02, 2013 | Samsung SyncMaster Computers & Internet
Pxe-mof exiting pxe rom
If you are not booting from a network, PXE-boot is the wrong boot option.
You have to change the boot order so that the PC will boot from your HDD. This can be set in the boot option in your BIOS.
Depending on the type of BIOS, you will enter F2 or Delete during the POST( when the white letters appear on the screen after you turned it on). This will enter you into the BIOS setup. boot options are usaully the last tab. Either disable the PXE-boot or change the priority so that it boots from the HDD first. Please, if you are unformiliar with this, reference the manual or ask someone with some IT background.
If the problem still exists after you configured the boot options your hard disk drive might not be readable. The BIOS just goes to the next availible boot device.
Apr 24, 2012 | eMachines T5048 PC Desktop
Hard drive not being recognised by compaq presario SR1975AN on warm boot
The hard disk may be running too hot.
The desktop case inside temperature maybe too hot. Check the power supply fan/CPU fan are operating correctly. You may need additional cooling in the desktop case an additional fan near the hard disk.
Mar 23, 2012 | Samsung SA07HD103SJ Samsung HD103SJ 1 TB...
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
May 15, 2011 | Dell Latitude CPI-A Notebook
Want to re-format MSI Notebook S420. Screen continuously shows windows 'loading' but never boots. I have the recovery CD but because the computer never actually starts, I'm not sure what to do with it!MSI
Hello megan_van
While your laptop is on, eject the optical drive and insert the recovery CD. Turn off your laptop via the power button, and turn it back on. The recovery CD should boot. Follow the on-screen instructions to do a clean install.
If the recovery CD doesn't boot, try holding down the C key after turning on your laptop. If it still doesn't boot, you will have to change the boot order in BIOS. Don't worry, this is easier than it sounds! Follow these instructions:
1. Turn on your laptop, and look for a message that says something like PRESS (USUALLY F2, F8, DEL, ETC.) TO ENTER SETUP / BIOS. Hit that key before the Windows logo appears.
2. After hitting the relevant key, you'll be taken to the BIOS setup utility. All BIOS utilities have different appearances, but it is basically a set of menus containing different settings for your laptops hardware. Somewhere on the screen (usually the bottom), is a set of instructions for navigation your way around the BIOS. Follow these instructions to navigate your way to the option for changing the boot order.
N.B. Since every BIOS setup utility is different, the specifics on where the boot order options are located varies from computer to computer. The menu option or configuration item might be called boot options, boot, boot order, etc. The boot order option may even be located in a general menu like advanced options, advanced BIOS features, other options, etc.
3. Once you've located it, use the navigational controls to place the optical drive above the hard drive (usually the +/- keys). To be certain that the recovery CD boots, it's probably best to move the optical drive to the top of this list.
4. Within the navigational controls, there is usually an option to SAVE & EXIT. Press this key. If there isn't, look for a menu option with the heading EXIT. A SETUP CONFIRMATION box will now usually appear asking you to confrm the changes you've made to the BIOS before exiting.
N.B. The SETUP CONFIRMATION box can sometimes be worded cryptically. Read the message carefully to be sure that you're saving your changes instead of exiting WITHOUT saving your changes!
Your computer should now restart automatically, and the recovery CD should now boot.
Hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | MSI MEGABOOK M510C Notebook
Samsung writemaster thinks its a cd drive
Has Bios Detect the Same? If so check motherboard/Samsung writemaster update bios/firmware.
If not reinstall DVD driver.
Nov 29, 2009 | Samsung Super-WriteMaster SE-S184M DVD-RAM...
Boot from CD does not work.
You should definately be given the choice to boot from cd, when you press F2 to get into the bios and go to boot options, what boot options do you have?
If you go into the bios you should have the choice to boot from ide (hard drive), cdrom, floppy disk, network (on some) and try other boot media.
Are you going into the boot option in the bios by pressing F2.
Jan 14, 2009 | Compaq Evo N610C Notebook
Cmos checksum error after flashing the bios
I had a similar experience after upgrading my RAM. When you reset your CMOS and have default settings maybe you should check if your RAM timings are correct. I could not get mine to load with both sticks in until I fixed the timings from the default settings.
Jan 20, 2008 | MSI K9VGM-V Motherboard
Computers & Internet Logo
51 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
