Question about Ruud Heating & Cooling
Rcba 4878gg21 i replace the filter because it wasnt blowing enough air an d noticed the part above was clogged with ice
    Genius:
  • Ruud Master
  • 1,363 Answers
Coil dirty, low air flow, low on freon, trying to set temperture to low.
Posted on Aug 17, 2015
  • 82 Answers
SOURCE: Can a clogged return air filter cause the
Yes! This is one of the most common reasons for evaporator and compressor freeze-ups. Change them at least 4 times a year. Second most common reason is closed dampers at registers or blockages at return air.
Posted on Jun 27, 2009
luker711
  • 91 Answers
SOURCE: AC is on but the air isnt cold
You may not have all components working, check to make sure the outdoor fan is working. Also listen closely to ascertain that the compressor is coming on,
Posted on Jul 10, 2009
SOURCE: Cooling Temperature Impacted
if you cleaned the evaporator and still high temperature means there is a loss of charge(freon)
Posted on Sep 02, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Blowin warm air, filter cleaned
Hello there:
There may be a small leak in the compressor that may have leaked out the refrigerant or on of the lines may have a pinhole leak in it
I would first have the unit recharged using a recharge kit and than check for any leaks also make sure that all of the fins on the compressor in the back are not damaged and are clear if you have a water howe spray the entire back down real good and if none of this helps than i would susspect a faulty temperature regulator or switch ok?
so please try all of these things that i have mentioned and let me know how this goes for you
Best regards michael
Posted on Nov 14, 2009
SOURCE: Filter location? Rheem Classic Super Quiet 80, RCBA 2457GG14XI
Open the two side panels. The filter is at the bottom held down with a wire spring. Release the spring and the filter can be removed.
Posted on Jul 17, 2010
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Cannot find a filter location for RCBA 4882GG21.
it is either in the bottom of the indoor unit itself, in the door below the inside unit (if equipped), or in the grill on the wall or ceiling
Sep 30, 2012 | Ruud Matching Split Air Conditioner
My unit wasnt working right so i took the front cover off and it is covered in ice.
Two things generally cause this problem. High outside humidity and a clogged air in take filter. Allow the unit to thaw completely, remove the air intake filter and clean it. Allow the filter to completely dry, before reinstalling. Never operate the AC unit without the filter in place.In addition. the unit may not have enough downward tilt at the rear. Generally 1/4" to 1/2" is required. so water will flow to the rear of the unit to the drain hole.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | Haier HWR08XC1 Thru-Wall/Window Air...
May 23, 2010 | Heating & Cooling
FRS262GEB Side By side Not Making Ice
Typically when this problem occurs there is a clog of some sort between the filter and the ice maker. Disconnect the filter, stop your icemaker and take the fill line off. Blow compressed air from the filter side, until air blows freely. Reconnect all parts and turn unit on.
Aug 22, 2009 | Frigidaire FRS3R5EMB Side by Side...
Jul 10, 2009 | Hunter Heating & Cooling
It's not blowing enough cool air out. It sometimes accumulates ice behind the filter.
seems like its clogged up and needs a good cleaning. fan could be all dusty, etc
Jul 09, 2009 | Heating & Cooling
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 25, 2007 | Daewoo FR-064R Refrigerator With Ice Box
Heating & Cooling Logo
55 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
