Question about Cuisinart DCC-1200 Coffee Maker
Dcc-1200 filter hello, the dcc-1200, I think it had too much water and it overflowed the filter. No coffee was coming down, so I cleaned it out and tried cleaning the bottom part of the filter which has this small plastic "umbrella" thing at the bottom. I can't get it to stay put now. before it was securely connected and now that I took it out to clean, it won't go back in and i can't figure out how it goes back. Any ideas? thanks Frankm
    Problem Solver:
  • 19 Answers
The filter basket fits in the machine in only one rotational position -
with the lift ring at the 5:30 position and rectangular tab at 12:00 o'clock - precisely!. Only in that position can it be fully seated so
the the cap on the carafe will open the valve at the bottom of the basket. If that valve stays closed, the basket will overflow and
no coffee will go into the carafe.
Posted on Jan 19, 2008
SOURCE:
Takes very long to brew 8 cups. 30 minutes or so
Hello! W/D here.
Your DCC 1200 is equipped with an internal filter designed to remove contaminants and it is accessed through the reservoir. I'd start with replacing the filter (don't forget to soak the new filter first before installing).
Here's the link to your manual and it gives a good description of changing the filter, and de-scaling your coffee maker.
http://www.cuisinart.com/products/coffee_bar/dcc-1200.html
Best regards, --W/D--
Jan 30, 2011 | Cuisinart DCC-1200 Coffee Maker
Machine shuts off during brewing
Hello bean_54806,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, bean. Positive feedback is appreciated. Good luck. NormanZ
Jul 08, 2009 | Cuisinart DCC490SA Coffee Maker
My problem is delayed brewing with my DCC 2000. Sometimes when I turn it on to brew it does so right away, but usually it delays for up to 45 minutes.
Hello judgemgj,
I think I can help you. This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down or the unit brews too slowly, but many people don't know about this fix. I hope this is helpful to you, judgemgj. Positive feedback is appreciated. Good luck. NormanZ
Jul 04, 2009 | Cuisinart DCC-1200 Coffee Maker
How to use the self clean feature of this coffee maker
Hello gerilind,
It is recommended to clean the system out about once a month with a 2parts water to 1 part vinegar, translated it is 8 cups of water and 4 cups of vinegar. Press the self clean button and the brew switch. Rinse with fresh water one or two times.
Should work for you. Don't forget to check the filter stick in the back left of the unit. Pull it out and remove the clogged carbon filters. Shine a light into the bottom of the cavity and clean out the debris left behind. You can get replacement carbon filters on Amazon, they are inexpensive. Reinsert the stick. Your coffee should be back to tasting excellently in no time at all.
I hope this is helpful to you. If it is, please leave positive feedback for me. I will very much appreciate it. Kind Regards, NormanZ :o)
Jun 24, 2009 | Cuisinart DCC-1200 Coffee Maker
Won't turn on ... just like the other 13 people indicated on this web site. It worked intermittently for awhile and then just stopped.
Hello georgewheele,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The shut down may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor shuts it down. If this does not help, you may have an electrical problem with the unit. Give it a try, you might be good to go again. I hope this is helpful to you, george. Positive feedback is appreciated. Good luck. NormanZ
Jun 08, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart coffee maker from costco, the grinds backed up twice.
It sounds like the release at the bottom of the basket was not open when you put the pot in to receive the coffee. You might check the release on the basket by takin the basket out, putting water in the basket and tripping (pushing up) on the botton on the bottom to see if the water flows through. It could be clogged.
You should clean the coffee maker about every 30 pots of coffee to keep scale from gathering in the heating tubes.
May 19, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Apr 01, 2009 | Cuisinart DCC-1200 Coffee Maker
Dcc-1200 not working
Probably dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart DCC-1200 Coffee Maker
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
Overflow
check to see that nothing is blocking the drain drop,you most likely have something in it as that would be the only thing that could do it.make sure the drain is open and not sticking
Sep 15, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
707 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
