Question about OKI C3400n Laser Printer
Unable to unlock Black cartridge
This is a brand new printer. I can easily unlock the Y, M & C cartridges but am unable to slide the blue cover on the K cartridge.
    Master:
  • 966 Answers
Mechanism is the same for all cartridges. Some printers like HP have an index finger space on it that you press down to release. See if your cartridge has similar groove.
Posted on Jul 12, 2013
5 Suggested Answers
  • 59 Answers
SOURCE: I have a C5150 laser printer that continues to
Remove the cartrdges and look to the top inside right of the printer. You should see 4 cut outs with sensors in that correcpond to the crtridges. Blow out these as there will be a bit of toner in there blocking the sensors. Happens quite a lot on these printers
Posted on Jul 08, 2009
  • 1752 Answers
SOURCE: printer does not print black ,changed cartridge
Run the head clean function.
Posted on Oct 14, 2009
  • 97 Answers
SOURCE: OKI image drum issue
Try this:
1) Power on printer while holding both the + & - buttons simultaneously; release when "Okiuser" is displayed.
2) Press + or - until "Engine Diag" Mode is displayed; press Enter and Diagnostic Mode xx.xx.xx will be displayed
3) Press and hold both Enter & On-line simultaneously until Eng Diag Level3 is displayed
4) Press + or - until Local Parameter Set is displayed; release and press Enter
5) Press + or - until it displays Factory Mode; if it displays Factory Mode Twice with an asterisk next to one then it is in Factory Mode; Press Enter, Press + or - until it displays Factory Mode & Shipping Mode on the display; then press and hold On-line & Cancel simultaneously; when it stops blinking an asterisk should be displayed next to Shipping Mode, which becomes the default mode.
6) Power printer off then on to complete the procedure.
Posted on Mar 29, 2010
wrinaldo
  • 185 Answers
SOURCE: I have an Okidata c5150n
On the right side of the machine there is a part which monitors the toners. The toner sensor board 42613601 may be dirty or defective. See #29 in the diagram
It may be something physical, too like something not fitting, etc., but generally I recommend to replace the board.
Posted on Nov 30, 2010
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Feb 14, 2012 | Lexmark Office Equipment & Supplies
Incorrect cartridges message on printer screen c4183. help me
Complete the following steps in the order presented until you resolve the issue. Step one: Remove and inspect the cartridge
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the carriage is idle and silent.
  3. Press down gently on the top of the cartridge to release it.
  1. Figure 2: Removing the tri-color cartridgec00484998.gif
  2. Slide the cartridge out and inspect it.
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear protective tape has been removed from the nozzle and electrical contact area. Figure 4: Removing the clear protective tapec00211538.gif
  3. Reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step two: Make sure the cartridge is compatible Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, click this link, HP SureSupply . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.
  1. If the cartridge is compatible, reinstall it in the printer.
    • Place cartridges marked with a triangle in the left carriage slot.
    • Place cartridges marked with a square or pentagon in the right carriage slot.
    Figure 5: Print cartridges installed correctlyc01091334.jpg Figure 6: Direction to insert the print cartridgesc01091335.jpg
  2. After verifying that your cartridge is compatible, reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step three: Clean the cartridge contacts
  1. Open the printer lid and wait until the carriage stops moving, and then unplug the power cord.
  2. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: If you are removing a tri-color, photo, or gray photo print cartridge, try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
  3. Dip a clean cotton swab in distilled water, and then squeeze it to remove most of the moisture.
  4. Clean the print cartridge contacts. Do not touch the nozzles. Figure 7: Cartridge electrical contactsc00832021.gif
  5. Clean the contacts inside the carriage, inside the printer. c00246272.gif
  6. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  7. Reinstall the cartridge, plug in the power cord, close the printer cover, and then try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step four: Reset the printer
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
  2. Open the cover of the printer and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message.
  4. Disconnect the power cord from the back of the printer and wait for one minute.
  5. Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step five: Replace the cartridge If after you have completed these steps you are still unable to resolve the issue, replace the cartridge. If you do not have a replacement print cartridge, go to the next step. Step six: Print in backup mode If you do not have a replacement print cartridge, you can still print in ink backup mode until the issue is resolved. Remove the problem cartridge and print with the remaining cartridge.
  • If you remove the tri-color cartridge, the printouts will be in grayscale.
  • If after you have completed these steps you are still unable to resolve the issue, service the product.
  • If you remove the black or photo cartridge, the printer will print more slowly and the colors in the printouts may differ.
I hope this solution will helpful for you. Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful. THANKS & Keep Using fixya
Jul 28, 2011 | HP PhotoSmart C4180 All-in-One Color...
I removed The deskjet ink cartridges(56/57) in my HP5650 to replace them with new ones. However, I am unable to install the new ones as the two bottom trays to hold them will not move. Can you help Joe...
Usually when you open the cover the cartridge holder should move to the center that will allow you to install the cartridge. If this is not the case you could force it to move by:
  1. Opening the cover as if you're installing a new cartridge.
  2. Unplug the power cord
  3. Lift the cartridge holder enough height to allow you to slide it on to the center
  4. After sliding, you should be able to install the new cartridge.
  5. After the installation close the cover and power up your printer.
Feb 24, 2011 | HP DeskJet 5650 InkJet Printer
Brand new lexmark printer, toner and cartridges installed, but get error 32 unsupported black cartridge error -tried updating drivers on lexmark site -tried taking cartridge out and reinstaling...
You could find the root cause by performing different steps. One of the easiest methods is that you need to make sure that the plastic protective tape which is usually used on the new black cartridge is off. Usually the user makes this mistake. This mistake might occurs due to absent-mindedness. The reason could also be some distractions which happen while loading the new black ink cartridge.
Nov 17, 2010 | Lexmark C546DTN COLOR LASER PRINTER ...
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
Canon pixma MP540 printer: unable to print black ink pages....ok with blue etc.
Have you checked the ink level on the black ink cartridge? It's probably out. Or if it's a new cartridge, make sure the tape covering the connecter has been taken off.
Nov 06, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
Have installed new epson black ink cartridge in c1100 printer. unable to press down locking bar on this new cartridge
Try re-inserting it again, L/H side should go in slightly ahead of the R/H. Give it a push & wiggle and it should lock in. An alternative method of fitting the cartridge is to open the top cover & remove the PCU. With the front cover shut you can rotate the cartridge "carousel" until the black is in the 2 O'clock poition when looking from the R/H side of the printer. You can now insert and lock the cartridge into place.
Please take a moment to rate this solution, thanks.
Apr 11, 2009 | Epson Aculaser C1100 Printer
Black toner replacement will not go into machine
If you cannot install the toner on the a cover
try this solution
close cover a
open cover b remove the pcu rotate the carousel when the specific toner that you want to replace facing the cover f remove the old toner and replace it with he new one. you will know that the toner is properly placed if the carousel is rotating freely
Oct 02, 2008 | Epson ACULASER CX11NF All-In-One Printer
OKI C3400n Laser Printer Logo
22 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
