Question about Braun Syncro 7526 Electric Shaver
Assemble during disassembly the L shaped spring steel for the switch flew out. I haven't found a place for it.
  • glenn yeoman Jul 14, 2013
    It's the only metal part that isn't permanently attached. Its longer side is some 3/4" in length.
The manual switch does not engage, found a wire spring in the box?
1) Copy following links:
http://waterheatertimer.org/images/WH-Off-pin-clip-washer-600.jpg
http://waterheatertimer.org/images/WH-lever-001-400.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
2) Examining the WH40 in my office, there is a clip washer that holds override lever in place against timer body.
This might be considered V-shaped spring.
Buy at local hardware store
3) Add comment and say what you discover, and attach photo
Feb 01, 2013 | Intermatic WH40 - Water Heater Time Switch...
Lexmark x6570 hinge is messed up so im getting cover open message
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to push it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover of the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Oct 05, 2011 | Lexmark X6570 InkJet Printer
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
My grinder starts slowly and takes time to build up to speed. It is a model 612 and does not appear to be a capacitive start motor. All I can see under the base plate is a relay. Thanks for your...
Hi and welcome to FixYa, I am Kelly
Inside your grinder either the stationary switch or the rotating assembly that actuates the stationary switch has failed.
Download this pdf file:
http://www.baldor.com/pdf/literature/CA506_0806_WEB.pdf Then go to page 9
The rotating assembly is this part number: (most common failure)
34RS2060SP
You must remove the end plate / cap to change this part.
The statonary switch rarely fails unless the rotating assembly damaged the contacts when the rotating assemble failed. When the rotating assembly fails you often find a spring and flyweight loose inside the grinder during disassembly. Should your stationary switch have failed try and get a number off of it so you can get the right switch. Otherwise you have to use NEMA code / Body type numbers.
Thanks for choosing FixYa,
Kelly
May 06, 2011 | Baldor 612 6" Bench Grinder 3600 Rpm Stamp...
Mess. saying cover open i cant seem to close the top down. the top cover seem to be off track or broken
Feb 05, 2011 | Lexmark X6570 InkJet Printer
60 02 error
Hi
I had the same problem on a customers 4250 and here is my solution.
It appears that the spring which holds the lifter motor upright was designed
without enough tension on it.
If the spring is removed and the motor assembly is allowed to fall to the
right when the paper tray is inserted the motor never engages the tray
and a 60.02 error appears. However if the motor assembly is held upright
while the tray is inserted the error message never appears as the motor
always engages.
I have found that a spring from a laserjet 4v toner cartridge is the same length
and shape but utilizes a heavier gauge steel.
When I used this spring in place of the OEM spring the 60.02 error message never appeared again.
Jan 12, 2011 | Office Equipment & Supplies
When pushing the soap dispenser drawer it does not spring open any longer. Is there a way to fix this?
Re: Soap dispenser door not opening properly...(in case you still need to know)
You might want to use a small mirror (and flashlight) to see where the the spring assembly fits. Turn the rod facing towards you with the flat side up. It attaches at the rear, top left corner, near a small opening on the back wall (shaped liked the assembly). Fits into the "grooves". Apply enough pressure and you will feel it snap into place.
Dec 31, 2010 | Electrolux EIFLW55I Washer
Printer cover
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Braun Syncro 7526 Electric Shaver Logo
27 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
