Question about Brother XL-3030 Electronic Sewing Machine
Brother XL 3030 not grabbing bobbin thread
Have rethreaded machine, changed needle....top thread is not grabbing bobbin thread - it appears as though needle is not threading down into bobbin.
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: Brother XL-5130 Sewing Machine
make sure that when you insert the thread *top hole bottom to top* that you turn the bobbin itself until you hear a click *that is the spring sliding into the ****.
Posted on May 02, 2009
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
SOURCE: The bobbin thread is not
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Posted on Aug 02, 2010
I've a Brother XL 3500 sewing machine and when I
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 11, 2013 | Sewing Machines
Needle gets jammed in fabric!
rethread the machine top and bobbin
make sure to use every thread guide it helps the tension
try a new needle--make sure it's the right needle for the fabric
being sewed
make sure the top thread has not come off the thread take up lever
here's a free manual if you need one, just click on the link
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_3025_3027_3030_EN_447.PDF
Dec 06, 2012 | Brother XL-3030 Electronic Sewing Machine
Needle not catching bobbin thread at all
Did you change the needle? If that doesn't solve the problem then it's probably out of time. Take it in for repair.
Oct 27, 2012 | Brother XL-5500 Mechanical Sewing Machine
Bobbin xl5130 is gathering but the stitch on top is fine. how do i adjust the bobbin tension
to adjust the bobbin use the top tension
also try rethreading the machine top, using every thread guide & bobbin making sure to insert the bobbin correctly into the bobbin case
also try changing the needle
May 22, 2012 | Brother Sewing Machines
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
I bought Brother sewing machine Model XL 2230, And could not get a good stitch. Keeps giving me loop either on top stitch or down stitch. Dont know if the single needle can't do straight sewing and dont...
The foot is on the side. Make sure it is clean. Take off the plate and remove the bobbin cleaning all the lint and thread out with q-tips. Oil if needed. Make sure you are using the same thread in the bobbin as on top. Rethread the machine making sure you do it correctly. Change needles using Schmetz as it is shorter and I have found Singer and white label needles are too long and cause problems and well as break easily as they hit the bobbin and cause looping. Not sure what you need to know about the foot. It should have a handle on it so you can put it up or down. Google Brother model XL 2230 and download a manual to find lots of info about your machine.
May 02, 2011 | Brother Sewing Machines
Its sews fine for a while and then the thread gets stuck in the parts around the bobbin. I've removed the bobbin parts and cleaned and it still does it.
change the needle
also make sure the needle is right one for the fabric & thread
clean under the needle plate where the feed dogs are for lint
check to see if the thread has come off the thread take lever
Nov 21, 2010 | Brother XL-3030 Electronic Sewing Machine
Thread keeps breaking
change the needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
Nov 21, 2010 | Brother XL-2600
Thread from the top needle gets pulled and tangled into the lower bobbin.
change the needle
rethread the machine-make sure to get every thread guide
make sure the thread does not come off the thread take up lever
clean under the needle plate where the feed dogs for lint
also clean the bobbin area for lint & loose threads
Nov 20, 2010 | Brother XL-5600 Mechanical Sewing Machine
Top threaded needle will not grab bobbin thread so I can begin sewing.
you might check your needle to see if it's bent
check in the bobbin area for any lint or loose threads
make sure there is a bobbin tail at least 2 to 4 inches long
hold the top thread tail ( at least 2-3 inch tail) as the needle goes down
Aug 03, 2010 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
37 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
