The codes are random. You'll have to contact the manufacturer with the unit's serial number to get the code. Be prepared to provide proof of purchase (they may accept a copy of the vehicle bill of sale).
Kenwood I am afraid ask you to activate a code of your choice after purchase.
The code you or the original keeper entered is NOT retrievable unless noted somewhere in your manual.
This means the unit has to be taken/sent to a dealer for a "bench" re-coding.
In standby mode press and hold bass boost/menu button to open options menu. use direction pad to toggle thru options. push center button in middle of direction pad to enter each option for adjustments clock adj, etc...
As far as I nkow, you need to contact Kenwood with the radio serial number to get the unlock code. In the past, they would not give it to you without giving them a special code from a card that came inside the package. You can always try though, give them a call, the number is on their website.
You have to go to a Kenwood car audio dealer in your area. They will pull the unit and get the serial # off the deck, call Kenwood and get you the code. If you pull it yourself you can save a little $... If you don't have the manual, go to www.kenwoodusa.com type in your model # under support and you can download install manual as well as user manual for free. Depending on the vehicle, it could be very quick or take an hour or so to pull the unit, it all depends on the mount. Hope this helps
Your radio will require one of the following procedures.
Type 1 During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears). Then using your remote enter your code.
Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3 Model# DPX-4020 and DPX-4030 Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key * Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key * Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key * Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
