Question about Baby Lock Esante
Motor is locked up
My needle broke while sewing and now my motor is locked up. Is there a way to reset it? There is no thread in the machine and it vibrates when trying to go back up. Thanks for your help!
  • Baby Lock Master
  • 7,365 Answers
When the needle broke it could have caused the machine to just time, it would be a good idea to have the machine checked at a sewing machine shop...
Posted on Jul 13, 2013
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: does not stitch lower thread
Make sure when you thread the machine you have the thread seated into the tension assembly on top, then make sure you have the threading ports locked and the switch in the proper place for each looper threading, the machine will only partially thread if you do not have the port locked and it will even still sew although not properly.
Posted on Dec 07, 2008
SOURCE: my ellure machine has got
I have 1994 airostar van 4.0 spark knocks on regular gas also scaned sead had slow injector puls
Posted on Jan 02, 2009
SOURCE: Inapproipiate needle stop position THEN Main Motor Lock comes on
The BELT was OFF. I guess it did that during shipment to me. So my husband just put it back on. THAT SIMPLE. It just kept making a motor trying to run sound and my husband took the left top cover off and seen it was only the belt. I was SO excited. It saved me a service call.
Posted on Feb 08, 2009
  • 3 Answers
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Posted on Mar 07, 2009
Reset timing on real industry sewing machine
most likely the needle thread adjustment is not tight enough and the thread is bunching up underneath
If it is stitching then the needle / hook timing is correct and it is the tensions that are out
Jun 20, 2016 | Sewing Machines
Does anyone have an idea of what might be wrong with my sewing machine? The bobbin thread is not being picked up by the needle.
rather sounds like the people that repaired it did not check the timing the bobbin has to be in the proper position when the needle passes it so the threads cross over .
Aug 10, 2015 | Singer Sewing Machines
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Mar 09, 2014 | Brother Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Why does my sewing machine lock up when I am sewing with it
the needle could be damaged
the top thread may have come off the thread take up lever
the bobbin may not inserted into the bobbin case correctly
there could be something wrong with the motor
the sewing machine could have a broken or damaged part
the sewing machine could be out of time
Aug 16, 2013 | Sewing Machines
My needle broke on my serger and i replaced it and now wont make stitch. please help
some times when you break a needle in a sewing machine or
serger it can cause the machine to jump time, it would be a good
idea to have the machine checked for a timing problem or to see
if when the needle broke it caused a problem with another part in
the serger.
Nov 12, 2012 | Sewing Machines
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
109 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
