Question about Wen 3816 16-Inch 42.2cc 2-Cycle Gas Powered Chain Saw
WEN Brand 3816 Gas Chainsaw - how do you start it...what is the protocal for starting it
We just bought a WEN Brand 3816 Gas Chainsaw off of craigs list...and It didnt come with a manual. In the past we have had only electric chain saws. I was wondering if you knew the protocol for starting one of these chain saws..is it as simple as just pushing the prime button and then pulling the rip cord? We have already got the 40-1 gas oil mix in it...just need to know how to start it
I need a repair manual for my 2007 WEN 3818 gas chainsaw. It will not start at all.
Before you get a manual try dumping out the fuel and mix up some fresh fuel. Try to start.
Jul 08, 2015 | Garden
Troubleshooting chainsaw
Sadly, the 3816 is not designed for larger timber. 38cc is only for smaller limbs, As a general rule also the largest timber to cut should only be 2/3 of the length of the bar
Jul 27, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
Fuel line diagrams
Wen might be able to supply a diagram.
Jul 01, 2014 | Wen 3816 16-Inch 42.2cc 2-Cycle Gas...
Poulan 3816, back fires through carburator, wont start.
water in the gas or carb needs to be removed and taken apart and cleaned
Feb 20, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
Poulan chainsaw oil leak
sounds like the small oil feed pipe inside oil tank as come away from the end. just push it back on you may need a pair of long snout pillers.. good luck
Nov 30, 2013 | Poulan Garden
I just bought a used 350 husqvarna chain saw fires up n stalls right away put new premium gas in it
Start with a few simple things, replace the fuel filter in the fuel tank, check the fuel hoses for signs of leakage, replace if required.
Dec 22, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Wen 3816 16-Inch 42.2cc 2-Cycle Gas Powered Chain Saw Logo
94 people viewed this question
Top Wen Garden Experts
Ted Maxwell
Thomas Perkins
Thomas Perkins
Tom Chichester
Are you a Wen Garden Expert? Answer questions, earn points and help others
