Question about Refrigerators
I have a kenmore side by side refrigerator model # 106.55526400 that is not cooling. Everything in freezer melted and now all in fridge side has ruined. Both fans are running and the compressor is warm and seems to be running also .I unplugged it and left it over night to try and restart but it still is not cool , I then took the back panel off of the freezer and checked the coils , nothing is frozen and no excess of water. The fan in the freezer seems to still be stopping at times for the defrost cycle and restarting so I don't think it is stuck in defrost. I also have removed the compressor start relay and I hear no rattling in it . What should I try next?
  • Refrigerators Master
  • 3,095 Answers
Hello Leigh Barrett,
I'm impressed... you are doing fine... looking at all the usual suspects... If your COMPRESSOR is running...
BEFORE GETTING to exotic... I would check and make absolutely sure the condenser (high pressure side) was clear & clean.
If the compressor is actually compressing the tube going to the condenser should be quite warm... likewise the tube coming from the evaporator coil (inside ..(becomes low pressure side after the EXPANSION VALVE)) should feel cool...
Compressor failures are rare.
There is another reason...
besides the board I am about to depict here for you...
You may have lost your refrigerant charge ...
Also Pretty rare trouble but does happen...
(not as horrible as it sounds... a competent refrigeration person
could find & repair leak & EASILY fit clamp on SUPCO, self-taping valves, evacuate & recharge the system (See SUPCO below).
((I have PREVIOUSLY published repair procedures & tools)).
Control Board 8201660:
I believe your model has this board INSTEAD of a
DEFROST TIMER... Further I think this board is in the center top of your refrigerator section ... Call appliancepartspros (below) for a CROSS-REFERNCE to an excellent VIDEO GUIDE.
(very similar refrigerator)
TAKE LOTS OF PICTURES BEFORE DISCONNECTING ...
(looking at the new part, you can see the board has NEW control keys as well... (the board is actually FOLDED for installation)).
Model # 106.55526400, Part # 8201660
APPLIANCEPARTPROS Number ap3675865 = $218
... (without regard for shipping)
http://www.appliancepartspros.com/whirlpool-cntrl-elec-8201660-ap3675865.html
Sears parts direct ... $184.02
(guaranteed Fit... (also without regard for shipping))
http://www.searspartsdirect.com/part-number/8201660/0046/106.html?pathTaken=partSearch&q=8201660
Partsselect
Whirlpool 8201660 CNTRL ELEC PartSelect
Supco self tapping valve
Amazon com SUPCO BPV31 OR TJ90BPV31 GENUINE FACTORY OEM ORIGINAL BULLET...
Posted on Apr 03, 2017
    Top Expert:
  • 50,335 Answers
Call a service tech .possibly it needs freon added . if so it is not a DIY process
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
abhishek33
  • 1239 Answers
SOURCE: After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
hi
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Posted on Oct 10, 2008
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
Harrybola25
  • 30 Answers
SOURCE: I have a Kenmore Side X Side Model 106.53642300,
yes it seems like compressor is burnt or relay could also b the faulty try replaceing the relay.
Posted on Jan 08, 2010
  • 6 Answers
SOURCE: freezer was all frosted up,
pipe between freezer & drip tray blocked possibly
Posted on Mar 18, 2011
Maytag side by side refrigerator - refrigerator and freezer both not cooling.
I had same issue , required a new compressor and regas. All cooling for fridge side is blown in from freezer
Jan 25, 2013 | Maytag Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Sounds like it has a defrost problem.  Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction.  Also, give me the entire model # from the sticker inside fridge.
Oct 17, 2007 | Refrigerators
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
