Question about Sony 1-474-209-11 G1HS Board PSC10307E M
SIGLA INTEGRATO Z401
Sigla f26 sulla lavatrice
F26 DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds. Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Oct 22, 2014 | Washing Machines
SE ENCIENDE EL LED P/S EN TOYOTA YARIS SPORT
en mi yaris 2008 se enciende una luz con la sigla p/s y no parte
Feb 03, 2012 | Toyota Yaris Cars & Trucks
Sulla mia lavastoviglie indesit de 74 evolution mi appare il codice di errore a12 mi sapete dire cos'?. Grazie in anticipo Fabio
Ciao Fabio.
A12 significa che c'e' un problema con il circuito di riscaldamento dell'aqua. A12 appare quando il modulo di controllo rileva che il circuito che include l'elemento e'aperto.
Elemento e circuito devono essere testati con il multimetro. Se l'elemento e' aperto deve essere sostituito. Se i cavi e l'elemento sono a posto, allora il problema e' il relay integrato nel modulo di controllo.
Il caso piu comune consiste in un elemento diffettoso.
In bocca al lupo.
G.
Dec 08, 2011 | Indesit 24 in. DE73 Evolution...
Microsoft office 2003 xp free download
If you want to download such a software for free, follow the steps below: 1.Install a torrent protocol client on your PC.Check out www.bittorrent.com 2.Search for 'Microsoft Office 2003 torrent free download' on Google. 3.After running the query, this was my best hit from www.kickasstorrents.com.The link is http://www.kickasstorrents.com/microsoft-office-professional-2003-sp3-integrato-ita-t3469307.html and I selected it as it has the highest number of seeders, and the comments on the torrent file report that it's working. 4.You may want to familiarise yourself with the bittorrent protocol by going to http://en.wikipedia.org/wiki/BitTorrent and learn how the bittorrent P2P protocol works.
Do have a great time ahead.Yours sincerely,
Brainiarc7
Jan 25, 2011 | Computers & Internet
Am o problema cu mp3 modelFM 6709 .IL CONECTEZ LA CALCULATOR SI ACESTA NU IL VEDE . AM INSTALAT DRIVERUL MI-A CONVERTIT MUZICA DAR PE MP3 NU IL VEDE CALCULATORUL .CIND IL CONECTEZ LA U.S.B. IMI APARE PE...
Nu neaparat, sigla usb arata ca el detecteaza ca a fost conectat la pc. Conecteaza-l la USB si deschide My Computer - daca e bun ar trebui sa apara acolo ca Removable Media - daca apare desachide-l si vezi ce fisiere ai si daca poti sa adaugi altele. Daca nu se deschide sau nici macar nu apare atunci e defect. Ca sa fii sigur incearca-l in alt pc.
Jan 23, 2011 | Computers & Internet
Errore F6
Errore F6 (F06) significa problemi con il motore, o con gli ingranaggi di trasmissione del motore.
La scheda di controllo della tua lavatrice rileva che il motore non sta girando alla velocita' richiesta o e' guasto.
Di solito , quando questo si verifica il tecnico controlla il motore, la trasmissione (motor coupling), l'unita di controllo del motore MCU (motor control unit), e sostituisce la parte difettosa.
Controlla questo link per avere piu dettagli su come risolvere il problema.
Non dimenticarti di votare la soluzione, possibilmente con quattro rombi azzurri.
Grazie.
Sep 03, 2008 | Whirlpool AWT5108 Top Load Washer
No picture or sound.
http://www.vancebaldwin.com/models/?TBA53AX61
Part Number Decription 23236623 #T461 FLYBACK TFB3086AD 24083013 #Z401 NOTE **SEE 50A61 FOR MAIN PARTS LIST ** 23549258 BEZEL 23427995 DOOR 23905094 IC STK392110 23311899 LENTICULAR SCREEN 23405040 MIRROR 23565302A OWNERS MANUAL 23311859 PROTECTIVE SCREEN 23306370 REMOTE 23311892 SCREEN FRESNEL CDSMPJTV03 SERVICE MANUAL (CD) 23527210 SPEAKER GRILLE
Feb 03, 2008 | Toshiba 53AX61 53" Rear Projection...
Toshiba 53AX61 w/ cracked screen
Lenticular = 23311899 $82.00 NLA
Fresnel = 23311892 $111.00
Protector = 23311859 $82.00
Andrews Electronics, Fox, Herman Electronics
........................................T.
Dec 14, 2007 | Toshiba 53AX61 53" Rear Projection...
Sony 1-474-209-11 G1HS Board PSC10307E M Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
