Cars & Trucks Logo
Bryan Posted on Jul 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2004 Bonneville an can"t figure out how
  •  Brad
    Brad Jul 14, 2013
    You may need to repost your question. I know less about how this fixya site works than I'd like. No help menu here. But it seems that once anyone gives an answer to a question, that question is removed from the unanswered quick view list. And I can't figure out how other techs can find it & join the discussion. If you repost I'll not give an answer so some one else can try to help you out.
Brad
Level 2:
Scholar:
New Friend:
  • Expert 85 Answers
  • Posted on Jul 12, 2013
 Brad
Expert
Level 2:
Scholar:
New Friend:
Answers
85
Questions
0
Helped
20461
Points
275
This option should be controlled though the radio. You'll need to follow instructions in owner manual.
5 Related Answers
Anonymous
  • 141 Answers
  • Posted on Jan 15, 2009
SOURCE: DASH LIGHTS DIM WHEN BRAKE OR LEFT BLINKER APPLIED
Pull the bulb out of both left side turn signals and check the filaments. As these are double filament bulbs, sometimes the filaments break and lay across the other creating a feedback issue.
Anonymous
  • Posted on Aug 06, 2009
SOURCE: Brake light, Turn signal not working rear right 06' Focus
I have a 2000 ford focus no brake lights. with the brake lights the transmission would not go into drive .replaced the brake light switch checked fuse replaced turn signal switch with no results then i moved onto the wiper switch and replaced it as much to my supp rise it fixed the problems
Philip Armitage
  • 437 Answers
  • Posted on Aug 30, 2009
SOURCE: 2004 monte carlo. turn signals dont work. the
try pressing the hazards on and off if they still don,t work replace the flasher unit. it is built into the hazard switch( all one unit ) change this and all will be good.
Vitally Alcher
  • 1645 Answers
  • Posted on Sep 09, 2009
SOURCE: 1999 ford crown vic dash light running light problem.
Check all the bulbs at tail end for parking and brakes, test grounds and harness for trailer. Check fuses. clean batery terminals, Re instal head light swich properly and make sure all wires conect.
Vitally
Testimonial: "thank you for quick response will try all of your suggestions will re post if no luck."
Anonymous
  • 119 Answers
  • Posted on Dec 17, 2009
SOURCE: VW Transporter,replaced the indicator stalk/switch but indicators
Hi
First check that the new switch is an EXACT match to the one you removed. There are a number of different switches that will all fit on to the column, but do not match exactly.
Re check that ALL the plug connections are fully pressed into place.
This is usually the problem and is an easy error to make
Good luck
John
How do i reset the computer on my 2002 pontian Bonneville so the security light will go off and my car will start? Or is there another way to get it to start? I have my keys, both my original and spare. I...
Turn the key on for 10 minutes, until the security light goes out. Then turn it off for 5 seconds, then back on and start the car. See if the light goes off. Don't open any doors during this time.
2answers
Flasher relay location Pontiac Bonneville 2004 removal and installation.
If the right side works it's not your flasher, Its your left side bulb, either front turn signal or rear tail light bulb.
Check oil light
Vehicle Systems do not monitor oil level & how clean it is
Stop using it & have it figured out
How do i turn off my check gauge light in my 04 bonneville
If you turn the check light off, you will erase the
codes you will need to start a diagnostic process.
Most times you get any light on your dash & you can
expect at least one a year,your vehicle is in need of repair
Check for codes & repair code related issues first
A code does not tell you any parts need to be replaced
A code directs you to a system & possibly a part of a system
that you need to do some testing on
2004 Jeep Grand Cherokee temp gauge high when heat is on
If your "check engine" light is turn on, I suggest scanned the PCM to know exactly what fault code is stored there. Additionally, could be some problem with the "temp sending unit".
Keep us updated.
1helpful
I have replaced the rear brakes pads on my 2004 pontiac bonneville - and now everytime i touch the brakes lightly - it makes a strange noise - Wayne
did you put wagner pads with built in shims, or another brand that has separate shims for the back of the pads?
The cruise control on my 2004 Bonneville Pontiac stopped working. I checked to fuse and it is still good. What could be the possible problem?
Check to see if the third brake light works. The brake switch works both the crusie and the 3rd brake light
2004 bonneville. head lights will not turn off..
Find and replace the headlight relay - its probably sticking relay contacts.
1helpful
2004 Pontiac Bonneville Check Engine Light
do you fill the gas tank with the key on?
Try disconnecting the battery for 1/2 hour an then reconnect and drive for 10 miles. It may run rough for this period. This will clear codes from memory.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
