Question about Craftsman 315.11701 Belt Sander
This question is about a Craftsman 315.11701, how do I change or tighten the belt?
How to tighten the drive belt on Craftsman 7.25 EZ Walk mower
If there is any adjustment at all it will be done on the drive cable itself not the belt. You will adjust the cable in order to pull more tension on the belt.
Oct 17, 2015 | Craftsman Garden
How to get my 14 craftsman band saw to run, no power
belt /blade might be too tight . loosen the tightener then turn on momentarilly
Mar 21, 2015 | Craftsman Saws
Got a craftsman mower 42 inch deck changed spindles and blades and deck still shakes belt may not be tightening up
did you put the blades on right ??? they have a star pattern and it needs to be lined up correctly... if that's ok does the belt have a bad spot in it or is the engagement mechanism operating correctly ???
Oct 20, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to tighten a craftsman LT1000 belt ?
There is an idler pulley that engages the mower deck and tightens the belt automatically on your model. Check to make sure the belt is routed correctly, return spring is in place and that your cable is operating smoothly.
Jul 19, 2014 | Craftsman Garden
How you tighten belt on sears craftsmanriding lawn mowermodel917270641
Which belt are you talking about? the drive belt or the blade belt, Usually there is NO adjustment for belt tightening unless you have a tension pulley is stuck and not doing its job
Jun 21, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman compressor timing belt
With a belt drive system, there is no timing to be set. Just put the belt on and tighten down. From there, you should be good to go.
Jan 06, 2012 | Craftsman Air Tools & Compressors
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
Craftsman 315.11701 Belt Sander Logo
55 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jim London
Jim London
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
