Question about Janome Sewing Machines
Janome new home 691 Power cord and foot pedal
Hi I am looking to find the power cord and pedal for this machine. It must have the 4 pin adapter.
  • Janome Master
  • 7,365 Answers
Try checking a1sewingmachines.com and call them about the parts you need.
Posted on Jul 13, 2013
  • 66 Answers
SOURCE: will cords from janome 8000 fit a janome 8080
some of the cords are interchangeable and the foot petal are also.
Posted on Jan 24, 2009
  • 69 Answers
SOURCE: power plug/foot pedal
Try here:
http://stores.ebay.com/Glendive-Sew-N-Vac_Power-Cords-Foot-Controls_W0QQcolZ4QQdirZ1QQfsubZ16QQftidZ2QQtZkm
Posted on Mar 01, 2009
  • 68 Answers
SOURCE: White 1600 SpeedyLock. Power, but foot pedal
When stepping on the foot control, does the motor hum or anything? Or is dead silent? If it sounds like it's trying to do something, the serger probably needs to be serviced. If it's silent, you probably need a new foot control.
Posted on Feb 25, 2010
Testimonial: "No sound. I ordered a new foot control. Thank you. "
  • 1116 Answers
SOURCE: foot pedal doesn't work
You may need a new foot pedal. Find a small applicance repair shop and ask them if they can test the pedal. Take the machine with you.
Posted on Mar 09, 2010
  • 980 Answers
SOURCE: Janome 657 sewing machine
You need to take a drawing of the plug on the machine and go into any sewing machine shop to match it up
Posted on Jul 14, 2010
Janome 627
Direct from Janome or any sewing machine shop should have them they should be standard YDK motors
Oct 08, 2013 | Sewing Machines
Foot pedal and power cord
also try sewvacdoctor.com for parts
Jul 12, 2013 | Kenmore 15218 Mechanical Sewing Machine
My janome sewist 509 is running really slow almost at standstill what can be causing this
could be the power cord not being plugges into the machine
enough or the power cord is going out
or it could be the foot pedal is going out
it would be a good idea to have the machine checked
Jun 27, 2012 | Janome Sewist 500 Sewing Machine
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
I have a janome 1 step sewing machine. last time I used it, I had stopped using it for only a few moments whilst I pinned the material so I could carry on stitching. It was still plugged in swhen suddenly...
I would call your dealer and get a new power plug put in. What i see here is a possible fire hazard. I do not know how old your machine is but I hope it is still under warrenty. By the way, The new Janome 7700 Horizon is at a bargain price right now. I am a sales rep for a dealer and we guarentee the best prices.
Sep 13, 2010 | Janome Memory Craft 9000 Computerized...
Will cords from janome 8000 fit a janome 8080
Jan 24, 2009 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
73 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
