Question about Pacer Ag Pump - 2in. Ports 127cc 9000 GPH Model SEB2PL E4C
I need to see a video on how to prime a pacer pump
  • 3,382 Answers
Look on uTube
Posted on Jun 18, 2014
How to adjust suction in a pacer
There is a special adaptor that is put between the cleaner and the suction port. It allows you to adjust it so there will be max suction (only sucking thru the unit) and less suction by opening a window to allow suction from outside the unit/at the exterior of the adaptor which less suction will be thru the pacer.
Jun 18, 2014 | Zodiac Pacer Pool Cleaner
How do I prime my pump
You need to give more information, model etc, the adapter does not get primed the pump does.
Jul 12, 2013 | Pacer Pumps 58-1457 Adptr Type F Male 3"
Pacer not "chugging" or moving around the pool. I
the pump may have a plugged up impeller or internal part wear , i need to know what type of pump yu have, also a plugged filter may be the cause
Oct 28, 2011 | Zodiac Pacer Pool Cleaner
I take hose to my pool suction. I then have my psi on pool pump going at 12 psi. the cleaner works. then it loses power/psi. I wait to see if it will still work . Then it stops working and does not...
It sounds like your loosing prime. I would chesk all the hoses for leaks. When you start the pump keep the hoses under water and see if the system works. If it does then pull the hoses one by on up out of the water bending them as you go to see if you can hear them sucking air. Good luck.
Aug 16, 2010 | Zodiac Pacer Pool Cleaner
The Zodiac Pacer Baracuda keeps turning on its side of upside down. what is causing this?
Probably not getting enough suction to hold it down on the bottom. Have you backwashed your filter ? Try that and see what happens
Jun 02, 2010 | Zodiac Pacer Pool Cleaner
Pool cleaner working very eratic , stop /starts
you probably need to replace the diaphragm, unthread the nut directly beneath the wagon wheel, press the white tube downward and inspect the rubber diaphragm for damage or deformity. this is the most common problem with the Zodiac Pacer.
Apr 07, 2010 | Zodiac Pacer Pool Cleaner
Zodiac pacer
Sounds like diaphragm is ripped
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
Pacer Ag Pump - 2in. Ports 127cc 9000 GPH Model SEB2PL E4C Logo
37 people viewed this question
Top Pacer Plumbing Experts
Paul Carew
Tom Chichester
Are you a Pacer Plumbing Expert? Answer questions, earn points and help others
