Question about John Deere Garden
JOHN DEERE X748 DIESEL WILL NOT START AFTER RUNNING OUT OF FUEL
JOHN DEERE X748 4WD. DIESEL TRACTOR WILL NOT START AFTER RUNNING OUT OF FUEL. NOT GETTING FUEL DO LINES PUMP HAVE TO BE BLEAD. HOW??
  • 10865 Answers
SOURCE: 750 diesel john deere tractor wont start
Hi Cassie, I can help you. Here is a brief course on bleeding a diesel engine, and the reasons why you need to bleed it.
http://extension.usu.edu/files/publications/factsheet/fm-01.pdf
Posted on Jun 19, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: john deere tractor x585 not getting 12 volts at fuel pump
To check pump u remove fender deck,unhook connector, put 12 volt power to it.I have seen pumps react to a swift kick to the fuel tank,NO JOKE.You first have to check fuses,2 on control board and early x585 machines had a single red wire near control board that was only for fuel pump.Remove right side air screen and check for voltage on the relay closest to the radiator.Red wires #231/232 feed your fuel pump relay.Current flows from that relay #655 pink wire and goes to your fuel pump .Also check#215 grey wire {fuseable link}coming from starter post,they WILL burn out,it goes to #221 red wire with inline fuse and feeds rear of the 2 relays,that is your EFI relay.You have 3 fuseable links coming off starter post,check all of them.
Posted on Jan 01, 2010
John deere 3140
cat converter plugged
Aug 06, 2014 | John Deere 5420 Tractor
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
Jun 11, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Jun 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
160 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
