The display on my panditigal e reader is backwards. How do I correct it and why is it doing this? I tried everything but taking the back off. Is that safe?
  • 7,627 Answers
Try posting to Tablets & eReaders .
Posted on Jul 13, 2013
My Kitchen Aid kdrp467kss09 oven's display is not working properly. everything else seems to work, but the small arrows for "stop"and"time" are lighted, and you can't put the correct time or even in...
From a tech position this is a tough one the display is fine you are getting a display it hooks to the User Interface which ties to the main control board if one were to take a guess based on experience I would say a bad UI called a Zodiac control not hard to change but not cheap either sorry I could not give you a definitive bad part this is the set back sometimes when dealing with computers all tied together
Feb 21, 2015 | Kitchen Ranges
My Reader Library icon will not open. I had purchased e books then it said there was a problem and I had to close. When I tried to open again it does nothing.
Hi there.
What OS are you running? Try to restoring your computer to the date before you installed the new version of the reader library.
If you have Windows 7, set eBook Library to Vista compatibility to get it to run.
Let me know what happens.
Thank you for using Fixya!
Jun 03, 2011 | Sony Reader Pocket PRS-300
Open tray error and game will not play
samesies! lol jk the same thing happens to me. the disc may be dirty, the disc reader (laser) night be messed up, etc. This is what i usually do-- I first turn off the xbox. take off the hard drive plug it back in. try to play again. if this does not work, while your xbox is horizontal, tip it up slowly. Dont make it vertical, just tip it backwards so its on the cords. since the reader may be old gravity willl help it read the game and let u play. Hope this works!
Nov 23, 2010 | Microsoft Xbox 360 Console
Everything on the screen is back wards and upside down! Tried pulling battery, did not work...
Hi,problem can be solved.It's not a battery fault,it's a flex problem.
The flex is located inside the phone and it allows the screen to display,So when the flex gets damaged the display will be disturb and it will start display backward pictures.
When you replace the flex of the phone,problem will be solved.
Take care.
Oct 14, 2010 | LG RUMOR Cellular Phone
How do I change Microsoft Reader as default?
http://www.microsoft.com/reader/info/tips/nolonger.aspx
Here's how to fix the problem:
  1. Shut down Microsoft Reader:
    a. From the Start Menu, tap "Settings"
    b. Select the System tab.
    c. Select the Memory icon.
    d. Tap the Running Program tab.
    e. Highlight Microsoft Reader on the Running Program list.
    f. Tap the Stop button.
  2. Tap OK.
  3. Start File Explorer
  4. Navigate to My Documents/Annotations
  5. Select and delete the .EBO file for the problem title. The correct .EBO file is the file that begins with the eBook title. If more than one .EBO file exists for the problem title, select and delete each one.
  6. Start Microsoft Reader again.
  7. Open the eBook. Let the device remain turned on, allowing Microsoft Reader to repaginate until it completes. This process should not take more than a few minutes. Microsoft Reader needs to perform this operation just once for each eBook.
How do I know if Reader is still handling background pagination on the title?
  1. Open the eBook in question.
  2. Begin reading the content.
  3. On the bottom of the Reader page, tap and hold the page number for a couple of seconds — then release it. The Riffle Control should be displayed: its appearance may take a second or two.
  4. The Riffle Control shows you where you are in the eBook. The leftmost number is the first page of the eBook; the rightmost number is the last page of the eBook. If the rightmost number is displayed in red, Microsoft Reader is not done with background pagination. If the rightmost number is displayed in black, Reader has completed pagination.
Jul 26, 2010 | Adobe Computers & Internet
Hp j5780 printer is printing backwards.
See link here or here, depending on your os, to correct this problem.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Someone changed a setting
The setting is in the Menu. It sounds like you went to the "Image" section which lets you make the adjustments you list. Try the "Source" menu, then "Mirror". That's where you will find options for Rear Screen Projection, which makes the image backwards.
Feb 05, 2009 | BenQ MP610 Multimedia Projector
Need to load pictures from panditigal frame to flash drive.
Hi Doug, I'm sorry, but your pictures are stuck on the picture frame. There is no software on the unit to move them out.
Jan 10, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Ethernet port,keyboard,card reader not working
Try taking out the battery and plugging into the mains to see if the battery is causing it. Worth a go.
Cheers
Aug 23, 2008 | Acer Aspire 5050 Notebook
Samsung a950 main screen display is backwards and upside down
My Samsung U700 had the same problem (display went back-to-front and colours all reversed and low-res.) It seems to be a problem with the flex cable (the cable between the main phone body and the sliding screen) wearing down and screwing up the data being carried between the display and the phone. Flex cables are cheap to buy and there's plenty of info online showing how to replace them yourself. Good-luck. Google: samsung u700 replacement flex cable
Jul 05, 2008 | Samsung SCH-a950 Cellular Phone
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
