Question about Baby Lock Esante
Babylock ESE2 lamp wiring
Have 2 model ESE2 machines. Lamp on #1 quit working. Replaced with new bulb, still not working. I moved working bulb from machine #2 and installed it in machine #1 and it does not illuminate. Also moved the original bulb from machine #1 that did not illuminate into machine #2 and it DID illuminate. Concluded that bulb is not cause of problem. Used meter to test power feed to lamp socket in machine # 1 with result of no power to socket. The machine does have power to motor and sews fine, all functions other than lamp continue to operate. Machine manual does not show or mention a fuse in the power line, but do not have a wiring diagram for the machine. Any knowledge of source of problem or location of and access to fine fuse ? Have not tried to remove the entire case to gain access and manual does not have disassembly instructions. Help & ideas are welcomed.
4 Suggested Answers
SOURCE: looking for a babylock esante manual. ESe2. The
I have a manual for the ESe2. If you still need it let me know
Posted on Feb 17, 2010
  • 1116 Answers
SOURCE: babylock manual sewing machine
You can download from this site - http://www.babylock.com/sergers/imagine/
Posted on Mar 21, 2010
  • 1564 Answers
SOURCE: Babylock Esante ESE-2 error beeps when performing embroidery arm test?
Something is wrong with the sensors. Take it in for a repair.
Posted on Sep 03, 2012
Quantum cxl. Why doesn't replacement lamp work?
Or it could be the incorrect bulb for the machine or if purchased from a secondary market, ie China, etc. I've purchased a replacement bulb from eBay and even though it was guaranteed to work in the machine, there is a lip on the bulb that prevents it from being inserted completely into the machine. Might be best to purchase an authentic replacement bulb from a dealer.
Feb 22, 2016 | Singer Sewing Machines
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
How do I change the light bulb in my Bernina 830?
I'm not specifically familiar with the 830 model, but all the other Berninas I've dealt with are very similar.
First, disconnect the power cord from the wall socket - safety first!
The housing for the lamp is in the hinged piece at the left (needle) end. It's hinged at the back (two hinges, one above the other like a door) and it's simply a matter of placing the palm of the left hand over the lamp switch with the thumb on the front above the needle and the tips of the fingers at the back of the machine, then opening the housing by twisting it away from the body of the machine from the front. It's held closed with a spring clip, so a little pressure may be required.
Once opened, the lamp and its holder are easily accessible. Remember the lamp is probably a bayonet fitting, so a little pressure to push the bulb into the contact springs and a slight twist in the same direction as you would turn a screw to undo it, and the lamp should come out. Avoid too much pressure on the lamp, as the glass part can part company with the metal base. If it does break, getting the metal base out is a bit of an issue, but it can usually be achieved with a pair of long-nosed pliers. Be very careful not to break the lamp holder - they can become quite brittle.
Having obtained a suitable replacement lamp of the same fitting size and wattage (most are 15 W), fitting it is simply a matter of pushing the lamp base into the holder and twisting it to lock it in place, then closing the housing.
Sep 02, 2014 | Bernina Sewing Machines
How do you place an embroidery design from a card into the machine memory? I have a ESe2. Thanks!
For the Brother NV1500 (aka Babylock Esante ESE2).
Bring the embroidery design onto the screen.
Press the save button in the upper right of the screen.(it looks like a pocket)
See pages 141 to 143 of your instruction manual "Saving Embroidery Patterns In The Machine's Memory"
Mar 18, 2014 | Baby Lock Esante
I need to know where to get a manuel for my ESante Ese2 embrodery machine. No problems now, but I haven't used it for a while and need to review things before I start up again.
The Babylock website has downloads. If you cannot find a manual, send a message to customer service. They are usually prompt to assist.
Apr 25, 2010 | Baby Lock Esante
Looking for a babylock esante manual. ESe2. The
Nov 16, 2009 | Baby Lock Esante
While sewing on the pfaff 7570, light keeps going on and off
Looks like you need a new bulb. This machine takes a bayonet style bulb, part number 2PCW is the generic one but you can pay more for a frosted one ($2-$4). To replace you need to remove the lamp cover. Depending on the age of your machine you may either need a phillips or #25 star (torx) driver. The screw is hard to find, it lift the handle up and look just to the rear of it on the left side, there should be a small square hole. The screw is under it. Alternately there is another, smaller hole just to the rear of the first one. You can take your seam guide (or a coat hanger) insert it and push down about 1", the lamp fixture is spring loaded and the end of the bulb will appear below while you push down. While holding down on the spring, push up on the bulb and turn to the left and it should pop out. (note some early models do not have the access hole to the screw, in this case you need to remove the top tray insert, 2 very small phillips screws, then you can see the lamp cover screw).
As to the battery problem, there is a cover on the bottom of the machine that you can pry off. There are 2 AA batteries inside. Remove and replace, you may need to clean the contacts if any corrosion is seen.
best of luck to you!
Jan 26, 2009 | PfaFF Creative 7570
I have an esante ese2.  is there a way to get downloaded images onto the machine?
you will need a card reader, and a blank compatible babylock/brother card.
Dec 25, 2008 | Baby Lock Esante
Sewing Machines Logo
47 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
